Author: Subject: BUDGET Spraygun Recommendation
stevebubs
posted on 9/3/10 at 09:57 PM Reply With Quote
Got some Amazon vouchers I need to use up.
Had a look on Amazon and they do the Earlex 3900 for about £80....is this any good for spraying my Fury?
Anyone any other recommendations for alternatives from Amazon?
[Edited on 9/3/10 by stevebubs]
stevebubs
posted on 9/3/10 at 09:59 PM Reply With Quote
Clicky
Mark Allanson
posted on 9/3/10 at 10:14 PM Reply With Quote
All depends if you are going to do the Fury in creosote
boggle
posted on 9/3/10 at 10:15 PM Reply With Quote
well its not a devilbiss but......
i would be interested in seeing your results....
u2u me for details
stevebubs
posted on 9/3/10 at 10:19 PM Reply With Quote
Preferably not...what would you recommend?
I have a 2hp/100Litre SIP oilfree compressor but didn't think that would be up to the job....
thunderace
posted on 9/3/10 at 10:23 PM Reply With Quote
i did it and was happy with the result but got a diferent spray needle from them for free for cellious paint .
http://www.earlex.co.uk/pdfs/wdacc18.pdf
boggle
posted on 9/3/10 at 10:25 PM Reply With Quote
i painted an rx7 with my 2hp 50ltr jobbie....
imho best budget guns available...i have 2...
budget gun
u2u me for details
stevebubs
posted on 9/3/10 at 10:29 PM Reply With Quote
budget gun
I'll refer you back to my Amazon comment....then compare £75 with $200...
stevebubs
posted on 9/3/10 at 10:32 PM Reply With Quote
I think I may have one of these in the bottom drawer of my cabinet but didn't think my compressor was up to it..
http://w ww.amazon.co.uk/professional-suction-spray-1-8MM-nozzle/dp/B002BNUUC2/ref=sr_1_3?ie=UTF8&s=diy&qid=1268173853&sr=8-3
ashg
posted on 9/3/10 at 10:39 PM Reply With Quote
I have got a devilbiss Gti and Pri also have a mini sata jet2000 for touch up's wouldnt touch anything else.
to be honest you will never get a perfect finish at home but with a reasonable 7-10cfm compressor and proper spray gun it will be 100x better than any result you can get from a rattle can.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
stevebubs
posted on 9/3/10 at 11:10 PM Reply With Quote
editted to add the word Budget to thread title....£200 on a spraygun is a non-starter....
Brommers
posted on 9/3/10 at 11:54 PM Reply With Quote
I've got two de Vilbiss guns - one FLG5 gravity fed and one FLG5 suction. Both work well for me, and they're about 70 quid to buy. I don't think there's anything better out there for the money.
Danozeman
posted on 10/3/10 at 06:26 AM Reply With Quote
I did mine with THIS Proper budget but worked well. I have done quite a few things with it which have come out well.
They do a more expensive metabo on but dont think its much different to this.
Dan
dogwood
posted on 10/3/10 at 07:58 AM Reply With Quote
I agree the devilbiss is prob the best.
But on a budget...
Ie me.....
I'm spraying at the moment with one of these
[linky
With a little 2hp compressor.
More than happy with the results
FREE THE ROADSTER ONE…!!
posted on 10/3/10 at 08:05 AM Reply With Quote
Earlex guns are actually very good, contact Earlex technical to make sure you have the right nozzle for the job.
posted on 10/3/10 at 08:10 AM Reply With Quote
not recommended since the creosote won't give a good finish - it needs an absorbant surface plus it will really really stink.
check out the land rover shows - there you will find spary guns, cheap but not nasty at all, for £ 10.
I have 2 ; one medium and one small for touching up (oor err!!!) and both are working great.
you need a compressor and air line - B&Q, screfix, ebay, M Mart.
if budget allows, fit the quick release couplings, man, I could have save 47 hours by not messing round with a spanner had I fitted them ages ago.
bartonp
posted on 10/3/10 at 12:19 PM Reply With Quote
In my youth, did a lot of spraying on old bangers with the back end of an Electrolux cylinder vacuum cleaner and an Electrolux spray gun like this one:
http://images.trademe.co.nz/photoserver/tq/64/115378664.jpg
didn't come out too bad after some cutting & polishing. Main thing is to get some thickness on there to cut back.
gingerprince
posted on 10/3/10 at 01:52 PM Reply With Quote
The Apollo Spraymates apparently get a good write-up: -
http://cgi.ebay.co.uk/Bambi-Apollo-Spraymate-1000W-DIY-Spray-System_W0QQitemZ180477277743QQcmdZViewItemQQptZUK_Body_Shop_Supplies_Paint?has h=item2a0548b62f
Certainly supposed to be better than the Earlex in a similar price bracket.
The only thing I don't know is they only seem to come with a 1.8mm nozzle and not interchangeable. I assume this is the reason they need more "finishing" after spraying?
stevebubs
posted on 10/3/10 at 05:27 PM Reply With Quote
thanks, gents - all useful stuff
Stephen
boggle
posted on 10/3/10 at 05:47 PM Reply With Quote
if you are painting 2k solid color 1.8 will be fine.....
u2u me for details
posted on 10/3/10 at 06:04 PM Reply With Quote
The first car I sprayed almost 40 years ago I used an older version of the Apollo Spraymate turbine system and it came out perfect. I used an enamel paint thinned with white spirit and left it in the shed to go off for a couple of days before removing the masking. My mates at work didn't believe I had done it myself it came out so well.
Sprytny
posted on 29/3/10 at 07:14 PM Reply With Quote
Where are these Land Rover shows. I want a spray gun for a first time user and I'd love to get into this...
