Author: Subject: How high above the tyre should cycle wing carrier be?
eznfrank
posted on 13/3/10 at 11:19 AM Reply With Quote
I'm going to bend the cycle wing carriers/brackets today as my mate is in his garage with his big vice. But I'm not sure how far above the tyre the bracket should be? I'm using Indy wings if that makes a difference. I was thinking somewhere between 15 - 25mm??
posted on 13/3/10 at 11:24 AM Reply With Quote
25 mm or 1 inch is about the right amount - remember that at speed the tyre is forced outwards due to centripetal force, not a huge amount but will matter if your gap is too small..
what peeps do is to tape block of wood to the try then put the wing on,
steve m
posted on 13/3/10 at 12:21 PM Reply With Quote
5mm is fine, well it is on my car
Mal
posted on 13/3/10 at 01:05 PM Reply With Quote
Don't forget that if the clearance is too small you may not be able to remove the
wheel without taking the mudguard off.
posted on 13/3/10 at 02:03 PM Reply With Quote
I had that problem at my first attempt and had to extend them.
posted on 14/3/10 at 08:43 AM Reply With Quote
Better aerodynamics with the arch as close to the tyre as possible , reduces the amount of lift on the front end IIRC plus it looks better IMHO
[Edited on 14/3/10 by rusty nuts]
RK
posted on 14/3/10 at 02:33 PM Reply With Quote
You can always tilt the wing forward so more coverage of the tyre is increasing aerodynamic efficiency. I used just enough to remove the wheel. Blocks of wood did the trick.
[Edited on 14/3/10 by RK]
RK
posted on 14/3/10 at 02:37 PM Reply With Quote
pic
posted on 14/3/10 at 02:54 PM Reply With Quote
It's always worth remembering that a seven-style car has the aerodynamics of a house brick, so practicality is more important...
