speedyxjs
posted on 17/3/10 at 07:08 PM |
Wider body panels - Much wider
Well after my previous thread, i think i may have to give up on my full bodied front end for my locost and move to a more conventional looking
seven.
My major problem is i am on a seriously tight budget (hence trying the £25 front end) and seven wings and noses arnt cheap in the standard size and i
need a 6" wider nose and much bigger arches (to fit 225/60/16 tyres)
hicost blade
posted on 17/3/10 at 07:16 PM |
http://cgi.ebay.co.uk/Hawker-Hunter-nosecone-NOS_W0QQitemZ110507959730QQcmdZViewItemQQptZUK_CPV_Aviation_SM?hash=item19bac9a5b2
carlknight1982
posted on 17/3/10 at 07:21 PM |
lol
Logic will get you from a A to B
Imagination will take you everywhere.
James
posted on 17/3/10 at 07:25 PM |
You're going to have to cut and shut the nose and wings anyway... so you might aswell buy secondhand and fill any damage at the same time.
James
- Muhammad Ali
hicost blade
posted on 17/3/10 at 07:26 PM |
http://cgi.ebay.co.uk/MASSEY-FERGUSON-135-165-168-175-185-BONNET-NOSE-CONE_W0QQitemZ170379587024QQcmdZViewItemQQptZUK_BOI_FarmingEquipment_RL?hash=ite
m27ab6a2dd0
[Edited on 17/3/10 by hicost blade]
gottabedone
Speedy said he wanted seven wings - not seven foot wings
speedyxjs
posted on 17/3/10 at 07:27 PM |
James
Would normal wings fit my bigger tyres?
robocog
posted on 17/3/10 at 07:28 PM |
Worth having a play with some fiberglass and cutting and extending some std sized bits?
(could then possibly get away with buying slightly damaged panels?)
Regards
Rob
norfolkluego
posted on 17/3/10 at 07:31 PM |
Or this one, comes with a free windscreen
http://cgi.ebay.co.uk/Harrier-AV-8B-Aircraft-Cockpit-Fuselage-Simulator-AV8_W0QQitemZ130356456531QQcmdZViewItemQQptZUK_CPV_Aviation_SM?hash=item1e59d9
ac53
speedyxjs
posted on 17/3/10 at 07:32 PM |
^^^ I think that would make it look worse than it does atm
ETA - and i can only just afford about 1/40th of that price
[Edited on 17-3-10 by speedyxjs]
hicost blade
posted on 17/3/10 at 07:34 PM |
ac53
Are you THE John Butler of Vindicator fame?? Ahhh your busted, I new I could weed you out one day
norfolkluego
posted on 17/3/10 at 07:36 PM |
ac53
If he owes you some money - NO
If you owe him some money - YES
hicost blade
posted on 17/3/10 at 07:37 PM |
http://www.mnrltd.co.uk/p_parts_bodywork.htm
MNR supply 260mm cycle wings, and the ABS is much better for taking a bash than GRP. Also it takes polyurathane paint like s**t to a blanket
mark chandler
posted on 17/3/10 at 07:56 PM |
Easy to widen a nose cone, wiggly cut down the middle, space the two halves then brace, gaffa tape between the halfs and backfill with fibreglass, may
add a few rods for strength.
When all hardened pull off the tape and fill.
My nosecone has a couple of inches added.
Make MDF/hardboard moulds for wings.
Allow £50 for resin, matting etc and buy in bulk + £25 for a scabby nosecone.
Simon did a good write up on wings
iank
posted on 17/3/10 at 07:59 PM |
I think the cycle wings russbost sells for the Furore should fit.
See last post in this thread for sizes
http://www.locostbuilders.co.uk/viewthread.php?tid=132093
[Edited on 17/3/10 by iank]
Anonymous
iank
posted on 17/3/10 at 08:04 PM |
For the nosecone you could have a go at making your own.
http://www.georgecushing.net/Nosecone2.html
or
http://www.georgecushing.net/QandD.html
Anonymous
blakep82
posted on 17/3/10 at 08:16 PM |
2nd hand damaged panels from racers/folk on here and repair is a good cheap way forward.
i got mine from race drivers, pretty much free really. a complete set of new panels is like £3500... yes, some of them were actually broken in half,
and badly repaired, or smashed up, but still a lot cheaper. you could easily get a damaged nose, cut it in half, widen it, and stick it all back
together
________________________
Dangle_kt
posted on 17/3/10 at 08:46 PM |
sey of free wings (as mentioned on other thread) for you to "experiement" on speedy if you want em?
speedyxjs
posted on 17/3/10 at 08:56 PM |
Oooh, yes please!
This just backs up what was posted here.
This thread was posted at 7:08 and now less than 2 hours later i have been offered a nose cone and a set of wings to play with.
This just shows what a fantastic forum this really is
Confused but excited.
posted on 17/3/10 at 08:57 PM |
ac53
That's just screaming out to be a trike.
