Author: Subject: Fiat ducato parts supplier
MK9R
posted on 18/3/10 at 10:11 AM Reply With Quote
Looking for a speedo cable for a fiat ducato van and struggling to find a good parts supplier online, any recomendations
delboy
posted on 18/3/10 at 06:09 PM Reply With Quote
Are you sure you need a speedo cable? they are really prone to the plastic drive on the box failing, the speedo then dosen't work and its often assumed that it's a failed cable. Just though it might be best to let you know, just in case.
MK9R
posted on 22/3/10 at 10:03 AM Reply With Quote
I pulled the cable inner out from the guage end, the cable was broken, so i assume its the cable!
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
MK9R
posted on 22/3/10 at 10:04 AM Reply With Quote
i've not removed the bit that goes into the box, can you tell if its failed by removing that?
Cheers Austen
RGB car number 9
www.trackace.co.uk
