barrie sharp
posted on 5/5/04 at 12:19 PM |
boot liner
Any one know where to buy a boot liner for a book locost or know how to go about making one
tfyt barrie
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
Wadders
posted on 5/5/04 at 12:24 PM |
I think MK do one for the indy, but i dunno if it would fit yours, Snoopy might measure one for you if you ask nicely
Al.
]Originally posted by barrie sharp
tfyt barrie
[Edited on 5/5/04 by Wadders]
Hugh Paterson
posted on 5/5/04 at 12:50 PM |
Boot liner
Make a male plug in MDF, router the edges to get a good radius, spray with a good quality filler primer to seal the surface, a couple of coats of
gloss when your happy with the surface leave for a week. On completion apply 5-6 coats of release wax, 1 coat gelcoat resin, allow to get tacky, 2-3
laminates of CSM applying resin between coats. Consolidate with a paddle roller, to squeeze out all the air bubbles between layers, let it cure and
pop it off 24 hours later. It would help if you built the plug with a shallow angle on the vertical sides tapering to the bottom to allow ease of
realease from the plug. Presto one boot liner.
Shug.
barrie sharp
posted on 5/5/04 at 03:52 PM |
Cheers shug i think i might re-think this one and just ask where can i buy one
(good discription though)
Got any sizes or prices snoopy thanks
tfyt Barrie
TPG
posted on 5/5/04 at 04:33 PM |
BOOTLINER/LOAD TRAY.Just another option to look at.I've used 1" weld mesh turned up at the edges and welded.It's fitted to the 19mm
box either side of the boot.Everything goes into plastic bags anyway and is bungy straped in.Tent roll will go on the underside of the
tray...
![](/galpreviews/a105825-boot3001.jpg) ![Rescued attachment boot3001.jpg](/gallery/a105825-boot3001.jpg) Rescued attachment boot3001.jpg
..Which was nice..
Hugh Paterson
posted on 5/5/04 at 05:47 PM |
Barrie, pity your so far South or I would do it for you
Shug.
barrie sharp
posted on 6/5/04 at 07:52 AM |
Cheers for the offer shug !
i have never had the urge to get too involved in fibreglassing.
tfyt Barrie
