speedyxjs
posted on 31/3/10 at 02:14 PM |
How to mount headlights
I got some 5 3/4" headlights with chrome surrounds on eBay for £5 (were advertised as spotlamps but i noticed the side light in them ) and
was wondering how best to mount them. They have an M18 mounting bolt thing (technical term) at the bottom.
cheers
[Edited on 31-3-10 by speedyxjs]
posted on 31/3/10 at 02:16 PM |
Round/oval bar, flattened at each end with a big hole through.
speedyxjs
Thanks but how to fit them to the chassis?
richardh
posted on 31/3/10 at 02:19 PM |
rivnuts?
Time for a change!
ironside
posted on 31/3/10 at 02:21 PM |
I welded two 6mm bolts to the chassis upside down (so thread sticking up in the air) then drilled corresponding 6mm holes in the headlamp bar.
Put the headlamp bar on the chassis so the welded on bolt threads go through the holes you drilled in the headlamp bar and secure with washers and
nuts. It will also double as an electrical earth for your lamps/indicators and anything else nearby.
HTH
big_wasa
posted on 31/3/10 at 03:27 PM |
Ive got two bits of 3mm wall tube about 50mm dia and same long. Ive welded a 3mm disc on top with 18mm hole.
Ive then cut a hole in the side and welded a tube to them and the chassis.
Hides the nut's and wiring.
http://www.locostbuilders.co.uk/viewthread.php?action=attachment&tid=90749&pid=756335
[Edited on 31/3/10 by big_wasa]
mad-butcher
posted on 31/3/10 at 03:49 PM |
looks a very sva friendly method, one of the things I failed on was the MK headlamp bar not having 3mm radius
tony
owelly
posted on 31/3/10 at 04:40 PM |
Behind closed doors??
http://www.ppcmag.co.uk
