Author: Subject: zx9 carb pipework
kylerichmond
posted on 4/4/10 at 12:35 PM Reply With Quote
zx9 carb pipework
Im having problems identifying what goes where.
I have zx9 b2 carbs withe throttle on the end, i have 6 pipe connections, 2 at the very bottom approx 6mm, and 2 in the middle 8mm and another 2 at the top 8mm these are between 1-2 and 3-4.
I put my fuel line on the middle 8mm connections and fuel squirted out the top two pipes, which connection should the fuel line plug on to? im confuesed
blakep82
posted on 4/4/10 at 12:38 PM Reply With Quote
my zx9rs are different, but the top 2 are supposed to be connected tot he airbox or breather. so if fuel comes out there, don't use the ones you already connected to
the ones with the throttle on the end have fuel between carbs 1&2 and 3&4, try the 6mm connections
________________________
jacko
posted on 4/4/10 at 03:34 PM Reply With Quote
any photos
jacko
posted on 4/4/10 at 03:39 PM Reply With Quote
top 2 leave open or put a filter on them
two of them will be for water block off dont use
the other 2 fuel in
the best way to check if the carbs are of the engine is blow down the pipes then turn them over keep blowing if its the right pipes the floats will stop the air
jacko
posted on 4/4/10 at 04:34 PM Reply With Quote
The fuel in pipes are in-between 1&2 and be-tween 3&4 at the bottom of the carbs
sharpshooter
posted on 12/8/13 at 03:49 PM Reply With Quote
Hello! I just bought carbs for my pinto and i don't know what is what.
1 i 2 Air inlet for lower slide chamber
3 i 4 I don't know
6 fuel inlet? 5 fuel outlet?
[Edited on 12/8/13 by sharpshooter]
jacko
posted on 12/8/13 at 05:47 PM Reply With Quote
Hi
1&2 = fit a small air filter
3&4 are fuel in
5 & 6 is for water do not use these
To check 3 & 4 blow down the pipes and turn the carbs upside down the floats will block you blowing
Jacko
sharpshooter
posted on 12/8/13 at 05:55 PM Reply With Quote
You're right! thank you!
jacko
posted on 12/8/13 at 05:58 PM Reply With Quote
Sharpshooter
can i suggest you start a new post instead of joining on to old posts
that way people will answer you quicker
Jacko
sharpshooter
posted on 12/8/13 at 06:12 PM Reply With Quote
I just did not want to duplicate titles and make a mess I have one question more. Is this line shows proper angle and fuel level?
jacko
posted on 12/8/13 at 06:52 PM Reply With Quote
Yes the little pip / pipe at the bottom wants to be vertical
carbs on manifold
carbs on manifold
[Edited on 12/8/13 by jacko]
40inches
posted on 12/8/13 at 07:06 PM Reply With Quote
You won't make a mess, people prefer it if individuals start their own threads, otherwise it's called "thread hijacking" and
most OP's (original posters) don't like it. I know I don't It's forum etiquette.
sharpshooter
posted on 12/8/13 at 07:11 PM Reply With Quote
Understood! i will make my own thread with Sierra
