Danozeman
| posted on 5/4/10 at 02:53 PM |
sticky vinyl on ali sides.
Has anyone used sticky vinyl on there ali sides? Will the exhaust melt it?
Dan
jacko
| posted on 5/4/10 at 05:14 PM |
Vinyl will take quite a lot of heat we use heat gun's to remove them off buses, but i dont think the heat of a exhaust will do it any good
+ vinyl's don't look very good with time if you cut it the cut opens up in time from the Sun heat
Steve Hignett
| posted on 5/4/10 at 05:17 PM |
I matched and applied vinyl to the RRR SprintR I built, and was told that this speific viny would be OK with the exhaust heat where it was coming
close to the body...
cerbera
I used it on my old car and never had a problem with it melting, although I did have a 2" stainless exhaust surround fitted.
Wadders
| posted on 5/4/10 at 05:58 PM |
Yes and No it won't. Stands up to stones pretty well too, mines been on years now.
Al.
grub
| posted on 5/4/10 at 06:07 PM |
mine never came off or melted tried to put a picture up but hey
jacko
| posted on 5/4/10 at 06:13 PM |
Is this the photo? Grub
Danozeman
| posted on 5/4/10 at 06:18 PM |
mmm Might have to get some ordered. Whats the best way of fitting it without air bubbles?
Dan
grub
| posted on 5/4/10 at 06:26 PM |
that will do nice cheers me dear
jacko
| posted on 5/4/10 at 06:27 PM |
We use soapy water in a spray / squeegee/ and a hair drier
where i work
It takes some doing to look right
bi22le
| posted on 5/4/10 at 07:39 PM |
i want to fit some on my striker when i get it as im not a massive fan of ali sides. Any tips or cheap places to buy it from would be nice!
Please read my ring story:
mangogrooveworkshop
| posted on 5/4/10 at 08:04 PM |
Wet wipes or a spray bottle of water.
Get the proper squeege.....
Steve Hignett
| posted on 5/4/10 at 08:22 PM |
Search Youtube for window tinting videos, it's the same principle...
RK
| posted on 5/4/10 at 09:41 PM |
Very sharp blade will allow the air and water to escape. Not noticeable if done carefully.
Danozeman
| posted on 6/4/10 at 04:47 PM |
wont the water make the sticky not sticky anymore?
Dan
RK
| posted on 6/4/10 at 10:21 PM |
You need soapy water to apply the vinyl, so it can slide around into place. Don't worry, it sticks once dry.
