kylerichmond
posted on 5/4/10 at 04:26 PM |
First time start zetec
Yeh wires on the coil were mixed up, swapped them and got it started, ran lumpy on idle with a little misfire randomly however when i put the choke on
it ran smooth, this was with just the edis connected and not them megajolt, is this normal? I also noticed that when i took the plug leads of whilst
running number 1 and 4 affected running but 2 and 3 didnt really, good spark on all cylinders and 70psi oil pressure, will the car smooth out when i
connect the megajolt? or will it be fuelling?
posted on 5/4/10 at 05:11 PM |
Where's the vid??
kylerichmond
posted on 5/4/10 at 05:49 PM |
was waiting for that lol, i will put it on asap
big_wasa
posted on 5/4/10 at 06:51 PM |
It wont run great on a flat 10 deg
Danozeman
posted on 5/4/10 at 08:09 PM |
If you got the coil wires the wrong way round you must have followed the early megajolt wiring diagram. Alot of people have done that.
As wasa says it will run cack on just edis.
Dan
