Daddylonglegs
| posted on 10/4/10 at 09:09 PM |
Progress at Last!
Making use of the good weather to crack on with the build (even managed to get some grass cut too - keeps the garage points up )
For those that remember this thread, the issue I had has been relatively easily
resolved.
I simply added some 1" box aluminium risers to the sides of the scuttle and 'Sikaflexed' them good and proper
The resultant addition of 1" to the height of the scuttle hasn't made that much difference to the lines. Managed to sort the bonnet too, not
exactly top-notch quality, but sound, and all mine and most definitely locost
All in all, a good day I feel
austin man
| posted on 10/4/10 at 09:23 PM |
is the nose cone in the correct positon, you cant usually see the bottom rail
Daddylonglegs
| posted on 10/4/10 at 09:43 PM |
It's a +442 which means 4" longer, 4" wider, and 2" taller. That's why the sticky outy bit under the nosecone
I'll be making a F/G extension to cover it up and also to mount the number plate on I think, not sure yet, bit close to the ground
dlatch
| posted on 10/4/10 at 11:58 PM |
ride height looks low at the front lower wishbones should be parallel to the ground.
the extra space under the nosecone is perfect for the number plate though
Daddylonglegs
| posted on 11/4/10 at 10:14 AM |
HAven't set the ride height yet, the shocks have been wound quite a way in to make fitting the 'bones easier, just haven't got round
to adjusting it all yet.
boggle
| posted on 13/4/10 at 02:46 PM |
looking great mate....
ive spent a fair bit of time on my bonnet now and im still not overly happy with it...
your car is going to look ace
u2u me for details
boggle
| posted on 13/4/10 at 02:47 PM |
forgot to say.....
i have a book size chassis and my nose cone sits the same...i had to lift it by 20mm for it to look right to the bulkhead..
u2u me for details
