Author: Subject: polishing scratches out on lexan polycarbonate
gregf27
posted on 11/4/10 at 05:59 PM Reply With Quote
Just finishing off putting a new slightly taller aeroscreen onto my F27 ( 4mm bronzed lexan polycarbonate)
just noticed a few light scratches on it, whats the best way to polish them out?
any ideas??
ta
Greg
speedyxjs
posted on 11/4/10 at 06:08 PM Reply With Quote
Iv heard toothpaste is good with scratches on glass but not sure about lexan.
plentywahalla
posted on 11/4/10 at 06:31 PM Reply With Quote
Polycarbonate has a very soft surface and any attempt to polish out scratches will probably make it worse.
Some polycarbonates are made with a thin acrylic capping for just this reason. Try and find an invisible area to experiment with to see if your is acrylic capped. If it is then a very very fine abrasive (could be toothpaste!) or rubbing compound like Farecla G10
Canada EH!
posted on 11/4/10 at 06:37 PM Reply With Quote
Try Meguiars plastic polish and cleaner, we us it on plastic aircraft windows, but as said try in a place it won't matter.
Gary 7
posted on 11/4/10 at 08:23 PM Reply With Quote
I have used brasso to remove scratches on perspex with good results, dont know if it would work on lexan may be worth a go.
austin man
posted on 11/4/10 at 08:42 PM Reply With Quote
I use p1200 and t cut afterwards
gregf27
posted on 12/4/10 at 07:53 PM Reply With Quote
cheers for the replies, I will try a few out on a scrap piece first!!
