Russell
| posted on 18/4/10 at 05:54 PM |
Help with paint problems please (what a mess!)
I've just sprayed grey primer on my gearbox and it's done this:
Image deleted by owner
What's going on? I'd previously comprehensively cleaned and degreased every nook and cranny of the gearbox then hand painted it using
"special metals" (including aluminium) primer, which went on with no problems at all. That primer has had 6 days to dry.
I decided to give it a blow over in grey primer ready for a silver top coat since the ali primer is a sort of desert sand colour - you can see it all
yellowy where the paint has crinkled.
Please, can anyone tell me what's causing this and give me any tips to prevent it happening in future?
I'm a bilingual illiterate. I can't read in two languages.
Airhead
| posted on 18/4/10 at 05:57 PM |
That looks like a reaction between the two primers?
Anybody?
boggle
| posted on 18/4/10 at 06:02 PM |
did you not want a crinkle effect??
u2u me for details
gingerprince
| posted on 18/4/10 at 06:05 PM |
Looks like this
MakeEverything
| posted on 18/4/10 at 06:07 PM |
Like Boggles skin?
I had this problem ona fuel tank. The sand colour primer was primer filler was it?
The only way to get around this now, is to get rid of all the paint and start from scratch, making sure the paints are compatible.
Kindest Regards,
Richard.
Russell
| posted on 18/4/10 at 06:08 PM |
Nope, I definitely didn't want a crinkle effect . Maybe I could get away with a crinkly gearbox but it hasn't happened all over, just
in patches. The photo above shows the worst bit.
Russell
| posted on 18/4/10 at 06:10 PM |
Like Boggles skin?
No, it wasn't primer filler, just regular brush on ali primer
MakeEverything
| posted on 18/4/10 at 06:15 PM |
Like Boggles skin?
ok, sounds like a similar problem to the one i had though.
Try rubbing off, and spray the whole lot over with a tin of normal white primer.
Kindest Regards,
Richard.
Ben_Copeland
| posted on 18/4/10 at 06:35 PM |
Yep definately reaction between the two paints. I'd just leave it as you probably won't see it anyway
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
prawnabie
| posted on 18/4/10 at 07:01 PM |
I take it the first primer was a hammerite product?
Russell
| posted on 18/4/10 at 07:02 PM |
No, it was a Blackfriars one.
Fozzie
| posted on 18/4/10 at 07:04 PM |
Another vote for dissimilar 'paints'....
Fozzie
Litemoth
| posted on 18/4/10 at 07:16 PM |
You've put a cellulose based primer over an oil based one by the looks of things.
Same happens with dissimilar top coat/primer combinations. Try mixing a tiny bit of each together before you paint. If they 'curdle' then
avoid overpainting
Easy to be wise afterwards of course....
Gutting
Russell
| posted on 18/4/10 at 07:28 PM |
avoid overpainting
Gutting
Gutting indeed!!! It's going to take an age to sort out that mess. It's an Audi transaxle that's going in a middy so the gearbox
will be highly visible when the rear engine cover is lifted and I want it to look tidy. I can't just leave it.
Thanks for the useful tip about "curdling".
Mark Allanson
| posted on 18/4/10 at 10:05 PM |
Its when you overcoat one paint with another when the lasts coats thinner is more aggressive than the first. eg You can coat celly with synthetic but
not vice versa
