Author: Subject: Hard tops and Roll bars.
morcus
posted on 23/4/10 at 03:29 PM Reply With Quote
This is mostly accademic but If your fitting a hard top on a car with a roll bar, is it better to fit it over the bar or under?
My thinking is if the bar was over the roof, the roof is less likely to break and hit you.
Thoughts?
tomgregory2000
posted on 23/4/10 at 03:48 PM Reply With Quote
over the bar.
speedyxjs
posted on 23/4/10 at 04:00 PM Reply With Quote
Over. Would look wierd under imho
indykid
posted on 23/4/10 at 04:11 PM Reply With Quote
how would you remove the hardtop if it was under the roll bar?
roll bar under the hardtop, definitely
tom
morcus
posted on 23/4/10 at 04:18 PM Reply With Quote
If you had the top in two pieces it wouldn't be hard. I agree it would look cleaner under and you'd have more head space though.
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 23/4/10 at 05:07 PM Reply With Quote
def over the bar, if the roof was under there would be a danger that the roof would collapse during a roll rendering the roll bar useless at protecting the driver.
