doddy
| posted on 29/4/10 at 05:58 PM |
cycle wing brackets by rally designs
hi im after a set of cycle wing brackets has any one used the rally design ones or these
http://www.ekmpowershop9.com/ekmps/shops/gtstuning/wing-stays---front-cycle-wings---sierra-uprights-108-p.asp
if you have what did you think and do you have photos
cheers doddy
[Edited on 29/4/10 by doddy]
blakep82
| posted on 29/4/10 at 07:07 PM |
never used either, but do your research
you'll find a huge difference between RD customer servive and GTS customer service. have a search on here
[Edited on 29/4/10 by blakep82]
________________________
prawnabie
| posted on 29/4/10 at 07:10 PM |
GTS supply rally design with alot of parts, this may be one of them.
If GTS is close to you then go down with the money and get them.
doddy
| posted on 29/4/10 at 07:26 PM |
yes i could go get them from gts as there about 1.5 hrs away i dont mind the drive have people had problems with postage then
blakep82
| posted on 29/4/10 at 07:27 PM |
oooooooooooohhhhhhh yes! me included
Ben_Copeland
| posted on 29/4/10 at 07:31 PM |
As far as i'm aware GTS no longer supply RD, RD now have stuff made in larger quanties the usual way....
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
big_wasa
| posted on 29/4/10 at 07:58 PM |
I had a pair for a set of cortina uprights and they no where near fit.
eddie99
| posted on 29/4/10 at 08:02 PM |
U2U sent!
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
scutter
| posted on 29/4/10 at 08:20 PM |
Big Wasa's correct, Cortina one's take a fair bit of modding to fit correctly, I also didn't trust the flat strip on both arms, so
welded a piece of round to the rear stay. You can just make them out in this pic.
  stripped
ATB Dan.
Wumps
| posted on 29/4/10 at 11:51 PM |
Hi, have you ordered a set of these? I am after a set also, will you let me know what they are like?
doddy
| posted on 30/4/10 at 07:30 PM |
hi im goimg to order them next week will let you know what i think
dlatch
| posted on 2/5/10 at 05:20 PM |
i had a set of the cortina ones and they were miles out from lining upto the mounting holes in the hub
sent mine back for a refund as it would be very hard to cure the fault and for all that work you may as well make a pair.
i ended up using a set from procomp which i am very happy with
