Author: Subject: Is fuel cap vent necessary?
RK
posted on 11/5/10 at 01:00 PM Reply With Quote
With turbo fuel injected engine? My new one with the funnel does not appear vented. Will this cause a problem? Thank you!
Staple balls
posted on 11/5/10 at 01:56 PM Reply With Quote
I'd've thought it'd only be needed if you have no other fuel breathers.
Bluemoon
posted on 11/5/10 at 02:55 PM Reply With Quote
Yep, you just need to let the air in faster than the fuel comes out...
just a vent pipe on the tank somewhere (some use a special roll over valve to stop fuel leaking, or just a U of pipe so the fuel can't leak out if you roll)..
In manufactured cars they use activated charcoal, and pull a slight vacuum on the tank to stop venting of petrol vapors (not required in locost)...
RK
posted on 11/5/10 at 10:29 PM Reply With Quote
I'm sorry, but I have no idea what you are talking about, so I gather I need another fuel cap, and I've just wasted 70 pounds plus shipping. I can't just ADD A VENT to an existing tank full of fuel. Thanks for the replies though.
Why can't I just bolt parts on, get it inspected, and go driving? Why? Really?
[Edited on 11/5/10 by RK]
prawnabie
posted on 11/5/10 at 10:33 PM Reply With Quote
Can you not remove the filler neck and add a bit of steel pipe with a breather in it into that?
RK
posted on 11/5/10 at 10:39 PM Reply With Quote
Sorry, again, but I don't understand. I don't weld either, by the way.
Do you mean drilling a hole in the funnel?
Staple balls
posted on 11/5/10 at 10:40 PM Reply With Quote
Drill a couple of holes in the cap out of sight?
Should breathe enough to do the job
RK
posted on 11/5/10 at 10:48 PM Reply With Quote
Now that I can probably do!! Thanks! I have a few more odd jobs to do on it before shipping it out to BC for provincial inspection there. Need to decide if i'm ditching my dodgy gauges for a digidash too. Making the new dash should be easy.
update: upon checking the new cap, this does not look possible. Any other ideas???
[Edited on 12/5/10 by RK]
