FFTS
posted on 30/5/10 at 01:40 PM |
Replacing VortX wrap around cycle wings.. Advise please.
Got some shiny new cycle wings for R1Becca. They are the full wrap around. Wanting advise to the following..
Is it best to remove the cycle wing support frame and then replace the wings or just remove the wings on the car?
Best way to cut the slots for the stays and the slant across the front. What to use to avoid chipping/cracking the gel coat?
Tank ya veri mutch
Chris.
Pdlewis
posted on 30/5/10 at 06:15 PM |
What I did for mine was to attach some L shaped ali to the cycle wing using a PU adhesive then drill holes in the L to mount to the wing stays this
avoids pracking problems as the PU absorbs the vibration.
To then put the bars through the wing I just drilled 2 holes with a hole saw.
Note:
To change the whell I have to undo the wing stays from the back of the upright make
Hope that helps If you want some photos let me know and ill try and got some tomorrow
Build Photo Album
Updated 05/02/2009
FFTS
posted on 30/5/10 at 10:02 PM |
Sounds good. Photos would be handy if not too much trouble.
Chris.
