dhutch
posted on 3/6/10 at 02:11 PM |
Speedo for MOT?
Mots due, speed cables come out of the gearbox, im busy. Do i need it?
jossey
posted on 3/6/10 at 02:13 PM |
yes you need a speedo.
:O)
and you cant rely on a GPS system due to time to locate.
sorry mate.
cant be too hard to "pop" back in the gearbox.
dave
[Edited on 3/6/10 by jossey]
matt_gsxr
posted on 3/6/10 at 02:15 PM |
but they probably won't notice.
2cv
posted on 3/6/10 at 02:17 PM |
quote yes you need a speedo.
My MOT tester did not use the rollers to check my speedometer and another tester I know says he regularly MOTs a Morris 1000 that has the same mileage
each year because the speedometer is broken.
Worth checking I would have thought.
Alan M
posted on 3/6/10 at 02:38 PM |
Speedo is not part of MOT testjavascript:icon(''
tony-devon
posted on 3/6/10 at 02:40 PM |
I know that for bike MOT you dont need one, and Im pretty sure that for car MOT you also dont need one
however under C&U regs you have to have one
I cant find any reference to a speedometer test or inspection in the manual, so if it doesnt say you have to have one, then you dont
but worth a phone call to the tester anyway
edit: must learn to type faster and then I wont look like a wally posting the same as the person above LOL
[Edited on 3/6/10 by tony-devon]
heavy is good, heavy is reliable, and if it breaks, hit them with it
richardh
posted on 3/6/10 at 03:19 PM |
if i'm not mistaken, an MOT is not actually allowed to drive the car per se so therefore cannot test the speedo.
Only DVLA can do that.
I could be wrong of course
Time for a change!
adithorp
posted on 3/6/10 at 03:31 PM |
Speedo not tested at MOT.
adrian
http://jpsc.org.uk/forum/
posted on 3/6/10 at 04:51 PM |
It is not a testable item but is a requirement.
IE you won't be failed on it but are likely to get an advisory.
The fact advisories are recorded in a central data base is starting to cause me concern --- someday insurance companies and "the traffic"
are going to start to use the info.
Of course you could always take the car to a certain well known fastfit outfit in my experience they only fail cars on stuff they can sell or fix.
posted on 3/6/10 at 04:54 PM |
Brakes can still be tested on the road with a Tapley meter under some circumstances.
davrus
posted on 3/6/10 at 08:56 PM |
As an m.o.t tester myself i can confirm that a speedo is not a testable item there for it makes no difference if it works or not or even dosnt have
one at all. Only drive a short distance up the road if it is a vehicle that cant be roller brake tested i,e 4X4.
Hope that helps
Davrus
adithorp
posted on 4/6/10 at 01:30 PM |
BT, thats very cynical! Don't forget they can do lots of other stuff like, play the piano, speak chinese, hypnotise young boys... very
usefull.
adrian
dhutch
posted on 10/6/10 at 11:26 PM |
Thanks all guys.
Passed today with no advisories without the speedo being tested.
Which is good because it appear that its not just a simple clip back on job as the drive rod between the 90deg vdo takeoff piece and the type9 box has
snapped off in the box. yay.
Daniel
