Author: Subject: windscreen wipers
alfasudsprint
posted on 21/5/04 at 07:34 PM Reply With Quote
windscreen wipers
right section for wipers???
what are people using?
i have an old beetle unit, very small and compact, 400mm centres, and another from a Brasilia, 540mm centres, bigger prolly more power. anyonme have any experience of these? what centre woulēd be ebtter. i think the beetle screen seems about right for the seven.
tim
zetec
posted on 22/5/04 at 05:22 AM Reply With Quote
Most use a Mini/Lucas motor and wheel boxes. I fitted a 2 speed unit and got away with not having to change the standard gearing which determines the blade sweep. Easy to fit as you just cut the rack to length to give correct spacing. Pic of rack/motor on photo archive.
[Edited on 22/5/04 by zetec]
