Author: Subject: Orange peel paint?
rich201283
posted on 14/6/10 at 07:00 AM Reply With Quote
Orange peel paint?
I have sprayed my topcoat on my bodywork, It came out really orange peel.
I have tried colour sanding with 1000 grit but there is still some orange peel, Would i be better sanding with 800 grit then shoot a quick topcoat over? The paint is celluose.
blakep82
posted on 14/6/10 at 07:02 AM Reply With Quote
is the air pressure too high?
________________________
rich201283
posted on 14/6/10 at 07:21 AM Reply With Quote
The air pressure was set at 35 psi
cliftyhanger
posted on 14/6/10 at 07:27 AM Reply With Quote
keep at it with the 1000 grade (with a little soap too)
It takes time and effort to get a good finish....
when almost there go to 1500 or finer. VERY easy to use too coarse a grade and end up regretting it....
Lots of causes of orange peel, mix to thick, gun to far away, poor gun, thinners too fast etc etc etc just sort it once it is on.
rich201283
posted on 14/6/10 at 09:01 AM Reply With Quote
Can i use a da with 1000 grit or would i have to do it by hand?
posted on 14/6/10 at 09:51 AM Reply With Quote
You can, but not a good idea with an electric one obviously!
austin man
posted on 14/6/10 at 10:10 AM Reply With Quote
flat by hand not electric or DA you may burn the paintyou could use psoo if you ar thinking of giving it another topcoat ot two. I think the paint was too thick for the pressure you are spraying at.
rich201283
posted on 14/6/10 at 09:58 PM Reply With Quote
Decided to flat back with 800 grit then shoot a couple of more coats
