Author: Subject: pinto rad
redeye
posted on 22/5/04 at 11:25 PM Reply With Quote
pinto rad
i know this has probably been asked before but
what radiator has everyone used for thier
pinto engine?
id been given one from a westfield but it deosnt wanna fit.
cheers
mangogrooveworkshop
posted on 22/5/04 at 11:38 PM Reply With Quote
The polo rad (see zetecs photo archive) slightly tilted back 152 from westy and thirty bucks from partco (you may have the right one) I will see what the number was Zetec said use a 15 psi cap on the bottle. macspeedy is using a carpri rad
redeye
posted on 22/5/04 at 11:58 PM Reply With Quote
just had a look at zetecs rad, its not the same as mine
was plannin capri rad , heard they fit well?
also wonderin about wat alternator that every one else has used for the pinto?
stressy
posted on 23/5/04 at 08:15 AM Reply With Quote
Capri rad should fit but may well need considerable tilting back to do so.
Not exactly efficient but does the job.
posted on 23/5/04 at 09:12 AM Reply With Quote
Mk2 Escort tilted back works for me. It's probably similar to a Capri radiator. I used the standard alternator with a bit shorter belt and moved the engine bay brace to the other side.
redeye
posted on 23/5/04 at 11:01 AM Reply With Quote
cheers guys
anyone got a capri rad that can give me the dimensions?
macspeedy
posted on 23/5/04 at 11:45 AM Reply With Quote
top to bottom 480mm and 485 side to side which includes some lugs for mounting, thickness is 60mm at lugs and 40mm for the core hope that helps
MK7
posted on 23/5/04 at 12:03 PM Reply With Quote
I used a rad from a nissan Micra, went in upright pretty easy and so far seems to work quite well with my 1.8 pinto.
The expansion bottle that clamps onto the side / rear of the rad can even remain in situ.
scoobyis2cool
posted on 23/5/04 at 02:35 PM Reply With Quote
I've used a polo rad, I would recommend you use a 'pull' type fan that sits on the back of the rad, I have used a 'push' type on the front, it does fit but it's VERY tight between the rad and the nose grill
Pete
Mave
posted on 23/5/04 at 05:42 PM Reply With Quote
From what year/type is your Polo rad?
James
posted on 24/5/04 at 12:46 AM Reply With Quote
I've fitted a Micra rad too- though not run the engine yet!
A nice alternator is the one from a Bedford Rascal van. It's a Mitsubishi jobbie (I think they're the same in the Vauxhall version) and is really small and light.
I've made a braket from part of the Rascal bracket plus a small plate of 3mm. Seems to have worked well so far.
HTH,
James
Mk-Ninja
posted on 24/5/04 at 07:37 AM Reply With Quote
Micra radiator. Dead easy to fit, and comes with fan, switch and integral expansion tank.
I'm sure I've got one, just don't know where I've put it
bob
posted on 24/5/04 at 08:29 AM Reply With Quote
MK2 escort rad blanked off at the filler worked for me. Rescued attachment front no body.jpg
