Author: Subject: wiper angle
stevegough
posted on 21/6/10 at 08:48 AM Reply With Quote
wiper angle
anyone had trouble with wiper angles?
I am about to fit my wiper system, but I don't like the way the 45 deg angle sits with respect to the screen - will it be ok or will I have problems using the wipers?
Any suggestions (except don't fit a windscreen etc !!!)
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
posted on 21/6/10 at 08:55 AM Reply With Quote
It all depends on what system you are using. The chrome top pieces angle the rocker boxes and come in different angles....
turbodisplay
posted on 21/6/10 at 09:10 AM Reply With Quote
Just bend the wiper arms to change the angle. That way the spring will maintain its pressure on the screen.
Darren
RK
posted on 21/6/10 at 12:37 PM Reply With Quote
And they will still not work properly. Good luck!! When you figure it out, fly over to Canada and help me. I've spent A LOT of time trying to get mine working with no success.
stevegough
posted on 21/6/10 at 04:11 PM Reply With Quote
I'm using mini ones - 45 degree plastic collars... Rescued attachment dad.GIF
Luego Locost C20XE.
RK
posted on 24/6/10 at 11:46 AM Reply With Quote
Exactly! Does anyone have a source for some of these ferrules with the different angle? I see running into problems if I take the grinder out and submit it to my pot metal ones.
stevegough
posted on 3/7/10 at 08:04 PM Reply With Quote
Wiper angle now sorted.
Finally SORTED! got some longer wiper mechanisms from Car Builder Solutions (65mm instead of 49mm) LINK
The only problem then was to find some thick - walled plastic tubing - I ended up using part of a pond waterfall tubing (two bits one inside the other) - honestly it was the only thing I could think of!!!
I then cut these as diagonally as I could, and now have a much better angle to the window - see the pic. ( I have also bent the wiper arm as Darren suggested). Rescued attachment better wiper angle.jpg
Luego Locost C20XE.
RK
posted on 4/7/10 at 02:28 AM Reply With Quote
I ordered some CBS mini boxes too (not installed yet) but haven't checked to see if they are long enough for that. Yours look great!
