kylerichmond
posted on 21/6/10 at 06:51 PM |
zx9 carb fault piston
I have a zetec fitted with zx9 carbs however I thought i was down on power however today when i was playing about i noticed that when i rev the car
the piston inside the carb is not moving, any ideas?, the butterfly is moving and i have checked the top cover and greased before put back, im not
sure whats at fault
whitestu
posted on 21/6/10 at 06:56 PM |
Check it's not sticking and check the diaphragm for splits.
Stu
r1_pete
posted on 21/6/10 at 07:12 PM |
Also check the plastic cap / carb body seal
kylerichmond
posted on 21/6/10 at 09:07 PM |
I've checked and found no splits, don't think the tops leaking, I've put grease around the rim to check for a good seal
