stevegough
posted on 22/6/10 at 03:31 PM |
edge of exhaust hole
as per the title - does the edge of the hole you make in the bonnet have to comply with the 2.5mm radius issue? I want to outline it with S/Steel.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
| posted on 22/6/10 at 03:49 PM |
It's difficult to get the old test probe to it but I just lined it with fall-offable trim just in case.... (though to be fair my exhaust port
was in the side of the ali sheet so blooming sharp).
Humbug
| posted on 22/6/10 at 05:12 PM |
Dunno, but if it's ali you can roll the edge of the hole over edge inwards using a former so it does meet the radius requirement
speedyxjs
| posted on 22/6/10 at 06:26 PM |
Iv been thinking about this for a while. My exhaust is steel and is pretty sharp. Im abit afraid putting rubber trim round it might burn?
stevegough
| posted on 23/6/10 at 08:32 AM |
I have made the stainless surround, and rolled tabs underneath and I don't think the edge will be an issue because of the 100mm probe, but I
think the outer edge might be a problem as this will be 'contactable'.
I could do one of three things -
1 - leave it off until after IVA.
2 - 'feather' the edge?
3 - fill up to the edge with laquer so it isn't an edge anymore - the S/S is only 1.5mm thick.
What do you think?
Photo to follow soon...
[Edited on 23/6/10 by stevegough]
Luego Locost C20XE.
stevegough
| posted on 23/6/10 at 09:17 AM |
photos....
Luego Locost C20XE.
stevegough
| posted on 23/6/10 at 09:19 AM |
more photos.... (It won't look like that!...I haven't taken the protective film off yet)
Luego Locost C20XE.
