smart51
posted on 5/7/10 at 01:34 PM |
how much of the tyre do you need to cover for MSVA or IVA?
Not only forwards and backwards but to the sides. Would a flat sheet (with folded over edges) curved round the tyre pass or do the wings have to
have some depth to them?
matt_gsxr
posted on 5/7/10 at 01:39 PM |
IVA doesn't care about the tyre.
If you draw a horizontal line across the middle off the wheel, then all of that wheel has to be "under" bodywork. That it if you look
vertically down then that bit of wheel should not be visible from above.
This was the old SVA rule anyway.
Matt
iank
posted on 5/7/10 at 01:44 PM |
That was certainly ok for SVA, and presumably MSVA.
Check out the arches on this firefox which passed first time.
http://www.davebence.co.uk/build_14.htm
Anonymous
MikeFellows
posted on 5/7/10 at 01:50 PM |
That car looks like I designed it
vinny1275
posted on 5/7/10 at 02:06 PM |
Don't they have to cover something like 2/3rds the circumference within the IVA now? ISTR that when IVA came out, some manufacturers had to
redesign theirs to cover more of the wheel than one that would pass SVA....
matt_claydon
posted on 5/7/10 at 03:02 PM |
The rules for IVA are much more complicated than SVA, but IIRC there's a decent diagram in the manual. They have to go to certain angles fore
and aft of the wheel, cover the full width of the tread within that zone, and not terminate more than a certain distance above the axle centreline.
Not sure for MSVA, although I didn't think anything had to be covered.
posted on 5/7/10 at 03:16 PM |
I've just flicked through the MSVA manual and I can't find any reference to cycle-wings being compulsory.
I'm guessing they would be required under Construction & Use regs and for MOT.
Can anyone confirm this as also being their understanding?
Cheers!
It's Evolution Baby!
Stott
posted on 5/7/10 at 03:23 PM |
Matt_Claydons post is correct^^^^ rules are 30 degrees fore, 50 degrees aft, not terminating more than 150mm higher than horiz centre line, full width
of tyre covered when viewed from above
[Edited on 5/7/10 by Stott]
Bluemoon
posted on 5/7/10 at 03:27 PM |
You could ring vosa to confirm which rule if any you need to comply with, found them very helpful on the phone in the past..
Dan
iank
posted on 5/7/10 at 03:40 PM |
Cheers!
For a reverse trike I'd treat them as essential, not from a legal sense (don't know if they're required or not) but from a practical
sense of not wanting a face-full of water or cow dung while driving.
Anonymous
tony-devon
posted on 5/7/10 at 05:55 PM |
MSVA mudguards are not required, nor are they needed for MOT, but are a legal requirement under C&U regs LOL
heavy is good, heavy is reliable, and if it breaks, hit them with it
smart51
posted on 5/7/10 at 06:49 PM |
Right, so I have to have them but anything goes for MSVA and MOT. Brilliant, thanks.
posted on 5/7/10 at 06:55 PM |
But I like watery cow-dung!
Seriously though - I'll be doing the bare minimum to get this thing through MSVA before they change the regs. I can then worry about
cycle-wings and such-like over the winter!
