Author: Subject: Bonding CF to metal
supercat
posted on 16/7/10 at 06:59 PM Reply With Quote
Bonding CF to metal
Thought this might be better here - I have Carbon Fibre rams on my TB's, but 3 of the 4 recently decided to part company with the metal mounting rings (luckily getting stuck in the engine bay!). The question is what to stick them back with? Needs to be something oil/petrol resistant with maybe a little bit of 'give' to overcome the vibration? It looks like they were stuck on with epoxy before but either it wasn't mixed properly or hasn't taken....
James
Volvorsport
posted on 16/7/10 at 07:01 PM Reply With Quote
jenvey bond them with epoxy.
www.dbsmotorsport.co.uk
getting dirty under a bus
RichardK
posted on 16/7/10 at 07:43 PM Reply With Quote
doesnt sikaflex stick everything to anything!
Think it fuel/oil resistant too
Rich
Gallery updated 11/01/2011
posted on 16/7/10 at 08:06 PM Reply With Quote
It didn't stick my Carbonmods front wings too well as I found out on the A14 at 70MPH!
vyperstrype
posted on 16/7/10 at 08:07 PM Reply With Quote
Ditto the above.
Where there's a will, there's a death!!
hobzy
posted on 16/7/10 at 08:39 PM Reply With Quote
Ditto twice for my scoop to as I discovered this morning on the A3, luckily 2 mounts held...
tomgregory2000
posted on 16/7/10 at 09:11 PM Reply With Quote
that sounds like bad prep to me
my wings were held on with sika 291 and were a propper bitch to remove to fit the bigger ones
Sikaflex does stick everything to everything but only if the PREP is done propperly
Dusty
posted on 16/7/10 at 09:36 PM Reply With Quote
Sikaflex is not resistant to petrol. Slowly turns to goo.
hobzy
posted on 16/7/10 at 10:03 PM Reply With Quote
Sikaflex does stick everything to everything but only if the PREP is done properly
Keep going... what might I have done wrong? Genuine question...
RazMan
posted on 16/7/10 at 11:02 PM Reply With Quote
I have to disagree - I have used it as a pump / sender gasket with no problems in nearly four years.
Raz
tomgregory2000
posted on 17/7/10 at 06:36 AM Reply With Quote
well the prep work i did for my wings and stays was to sand the inside of the wing and the metal stay with grade 24 (its just like small rocks) sand paper and then degreased with acetone and then degreased with acetone and new cloth and then a final degrease with acetone and new cloth, then aply the sikaflex and strap the arch in place and do not move it for 48 hours
thats it
cliftyhanger
posted on 17/7/10 at 08:53 AM Reply With Quote
Plus you need to get the corect sikaflex. And maybe avoid the cheaper options of "similar" products.
Must say though that proper sikaflex is proper expensive (at least compared to tigerseal etc)
posted on 17/7/10 at 12:03 PM Reply With Quote
I used a brand new tube of Sikaflex , cleaned and degreased the wings and stays several times , left them for 48hrs as above and the wing still came off. My old GRP wings were still on after 5 years stuck with the same type of Sikaflex and yes it was genuine Sikaflex
supercat
posted on 17/7/10 at 03:22 PM Reply With Quote
I'll give epoxy a go - any suggestions what I should clean them up with?
James
