Author: Subject: Sikaflex
Bumble
posted on 20/7/10 at 02:30 PM Reply With Quote
Sikaflex
How do you all stop the Sikaflex or similar from drying up after opening and blocking the nozzle?? Bl**dy annoys me every time. I've tried various methods none of which are ever very successful. Is there some trick I'm missing??
Matt
posted on 20/7/10 at 02:33 PM Reply With Quote
Just an idea but it's solvent based so wouldn't keeping it in the fridge / freezer work.
balidey
posted on 20/7/10 at 02:34 PM Reply With Quote
Get extra nozzles. Make sure you leave the nozzle full so its that bit that dries up, not the tube. Then just use a new nozzle. They are meant to be dispossable. As far as I know there is no good way of saving a nozzle. And we use a couple of hundred tubes a week at work.
Dutch bears have terrible skin due to their clogged paws
sucksqueezebangblow
posted on 20/7/10 at 03:58 PM Reply With Quote
As far as I am aware, once it is opened it is going to go hard whatever you do. It lasts a couple of days before going off in the tube. I try to plan ahead and have enough jobs ready to use most of a tube at once. Or just resign myself to the fact that the leftovers will be chucked away.
RazMan
posted on 20/7/10 at 04:16 PM Reply With Quote
I put a Biro cap over the end which delays the inevitable hardening for maybe a couple of weeks but basically, use it or lose it There must be a market for smaller tubes of PU adhesive and I would love to buy a couple for those smaller jobs. I discovered that some of the black gasket compounds are almost identical and I have used them with good results.
Also remember it has a limited shelf life so even if you have a few unopened tubes hanging around in the workshop, they will go off after a year or so.
[Edited on 20-7-10 by RazMan]
Raz
Canada EH!
posted on 20/7/10 at 04:31 PM Reply With Quote
I usually stick an old nail the size of the nozzle inside the nozzle then pull it out with pliers when i need to use it again. Works for me.
stevegough
posted on 20/7/10 at 04:48 PM Reply With Quote
wot he said, but I use a woodscrew, - screw it in, clamp in the vice, and pull it out whilst increasing the pressure using the pump action of the gun. Or, indeed, get another nozzle.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Wadders
posted on 20/7/10 at 05:23 PM Reply With Quote
It's moisture in the air that cures it once opened. Putting it in an airtight freezer bag helps, but iv'e never found a definitive way to stop it going off.
Al.
dave r
posted on 20/7/10 at 05:34 PM Reply With Quote
fridge does work, but i find that the piston at the other end of the tube tends not to be a good enough seal, and you break the mastic gun, breaking the cured sikaflex at the end
we use a sika product at work that is in sausage tubes, that go in a different gun.... anyone know if you can buy pu adhesive in this style package ?
dazzx10r
posted on 20/7/10 at 05:48 PM Reply With Quote
I use a self tapping screw in the end of the nozzle, seems to last ok for me, when re-using it i have found its best to warm the tube
russbost
posted on 20/7/10 at 05:53 PM Reply With Quote
I use a similar product, which uses a different gun & comes in sausage tubes (like a plastic bag), I'm not sure if it's actually a PU sealant & wouldn't use it for anything that was "stiction critical" but it is way better than silicon for adhesion & miles cheaper than sika + it doesn't go off, just leaves a little solid bung at the end of the nozzle that you can easily remove. By the time you've used a couple of tubes you've more than paid for the gun & are saving money - to say nothing of saving your temper when the bl**dy Sika has gone solid in the tube again!!!
twybrow
posted on 20/7/10 at 06:29 PM Reply With Quote
I go for a woodscrew, then a wrap of clingfilm, and make sure you store it somewhere cool and dry. It is warmth and moisture that sends it off. My last tube was still usable 6 months after I opened it...
