Author: Subject: Black Flush Fitting Fuel Caps
MikeFellows
posted on 20/7/10 at 09:46 PM Reply With Quote
I want an aero look fuel cap i.e flush fitting and in black (i guess it will need to be anodised around fuel)
merlin motorsport sell a good one but its £112.17 + delivery! (Clicky)
anyone know of a cheaper source?
[Edited on 20/7/10 by MikeFellows]
adithorp
posted on 20/7/10 at 10:13 PM Reply With Quote
Rally design do one.
http://www.rallydesign.co.uk/product_info.php?cPath=281_972&products_id=7973
or europa...
https://www.europaspares.com/FUEL_CAPS_and_HOSE/AERO_FUEL_CAPS/AERO_FUEL_CAP___2_00inch_WITH_6_HOLE_3_00inch_PCD_FLANGE___CAP3SFB__2591.html
adrian
http://jpsc.org.uk/forum/
MikeFellows
posted on 20/7/10 at 10:18 PM Reply With Quote
neither are particulalry cheaper
the europaspares one is + vat so £110 ish
the rally design one requires the filler hose at a further £14 then Vat again making it around £100
they seem awefully expensive for what they are
iank
posted on 20/7/10 at 10:25 PM Reply With Quote
Only cheap way I know is to get one from a motorbike and add a funnel.
I would agree they seem unreasonably expensive.
Anonymous
MakeEverything
posted on 21/7/10 at 07:17 AM Reply With Quote
A mate and I grafted the top of a fuel tank into the side of a hot rod once. Looked very good, and worked equally as well.
Obviously, the tank was no good after that, with a bloody great square hole in it!
If you do that though, be mindful that it is a FUEL tank, and that it should really be filled with water when you cut it.
Kindest Regards,
Richard.
Irony
posted on 21/7/10 at 09:11 AM Reply With Quote
I seem to remember that Frost's do a home anodizing kit for about £60. You could get this and anodize a normal aluminium fuel cover. You'd probably end up spending more but you could anodize to your hearts content after that!
Irony
posted on 21/7/10 at 09:26 AM Reply With Quote
Also I suppose you could spray it with the correct paint. I use Jotun Paints hardtop flexi for my parts and nothing takes it off when wet let alone dry. Cleaning brushes is hard as nothing will touch it not even petrol or brake fluid. The only thing that gets rid of once dry is either a sharp metal object or the angry grinder.
