kylerichmond
posted on 26/7/10 at 05:25 PM |
Zetec type 9 clutch release bearing
I fitted a 2.0l zetec silvertop to a type 9 gearbox with a 1.8 retroford flywheel re-drilled to take the standard pinto clutch, my problem is what
clutch release bearing should be fitted?, there is lots of confusion out there, i have a feeling that the one already fitted is a cct132, however many
people recommed the cct133, also the 3rd option is ct303, how do i tell which one it is?
The bearing i removed is an INA number F-89958, Ford number 8388-7548-aa, nobody seems to be able to match of cross reference it
posted on 26/7/10 at 05:27 PM |
CT133 Capri one is what you need.
If all else fails try GMSCAPRISPARES in Coxhoe.
RichardK
posted on 26/7/10 at 05:54 PM |
^^ What he says
Rich
Gallery updated 11/01/2011
big-vee-twin
posted on 26/7/10 at 06:18 PM |
I have a new one on sale on Ebay, if you're interested here's the link
linky
http://www.triangleltd.com
posted on 26/7/10 at 06:22 PM |
Butee D'Embrayage... MINT
lotusmadandy
posted on 26/7/10 at 06:41 PM |
Kupplungsausrucklager is far funnier
austin man
posted on 26/7/10 at 09:20 PM |
shouldn't it ne the standard sierra bearing, the capri item is recommended when using the zetec clutch with a type 9 box.the sieera / pinto
pressure plate springs sit significantly higher than the zetec plate
kylerichmond
posted on 27/7/10 at 08:19 AM |
From the pictures, it looks to me that ive been using a standard type 9 bearing and its been working fine, it worked well although the pedal was a
little high
