m0csi
posted on 27/7/10 at 08:52 AM |
Alluminium Rear Panel Locost McSorley+442
Can anyone help ... I am looking for a rear panel for my locost ... I could buy a alluminium sheet to shape ... but not got the tools ... Anyone know
where I can get one made ... Thanks Mike ...
interestedparty
posted on 27/7/10 at 09:00 AM |
Buy a cheap jigsaw and some decent hacksat blades, and if you don't already have them a cordless drill with some 4mm bits, some 4mm rivets and a
rivet gun, that lot will still be a lot cheaper than getting someone else to do it, and you can always sell them after
m0csi
posted on 27/7/10 at 09:07 AM |
Hi ... Thanks for your prompt reply ... The problem will be the roll around the sides ... how did you go on doing yours ... Thanks again ... Mike ...
nige
posted on 27/7/10 at 09:30 AM |
i used a fibre glass one and cut n shut
cut it and then clamp it with some 2x2
timber then fibre glass the join
then add some on the bottom
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
interestedparty
posted on 27/7/10 at 10:52 AM |
I'm not using aluminium myself. Do you have the build your own sportscar book from Haynes, there is a section on it in there.
ashg
posted on 27/7/10 at 11:32 AM |
have a look in my photo bucket there are some pictures showing how to do it in there.
http://s707.photobucket.com/albums/ww75/ashgardiner/
all you need is a sheet of ali something to cut it with, a roll of wall lining paper to make the template and plenty of clamps, scraps of wood.
rivets to hold it on and finally a couple of different size hammers.
edit: If a fool like me can manage it then anyone can
[Edited on 27/7/10 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
scoop
posted on 27/7/10 at 05:53 PM |
I put a thread on here a couple of years ago and got a lot of good advice. i didnt even make a template. Just need patience and nylon hammers not
metal. You just take a few nicks out above the curves and beat it evenly and slowly. When you have marked the hammer just sand it smooth and start
again.
m0csi
posted on 27/7/10 at 11:41 PM |
Thanks all for the advice going to make own ... Think the bonnet will be the most difficult ... Mike
