sonic
posted on 23/8/10 at 08:55 PM |
Clutch release bearing question
Hi all
Could one of you smart guy's answer a question for me.
A guy down my street has been talking to me about having to change the clutch release bearing on his BMW 3 series and we differ in our opinion of how
it is located and works.
The reason it needs changing is that when the clutch pedal isnt pressed it sounds dry and whines badly as sood as you push the pedal down it stops
with no noise,if you put it in gear and drive away you can here it whineing.
I said it is a bearing that is spinning until you press the clutch and it make contact with the preasure plate and then it stops turning whilst you
select a gear and then when you release the pedal it starts to spin again and that the release bearing is connected to the actuator or arm
Am i right?
He has a completly differant idea and said that the preasure plate and clutch plate has to come off to change it
Stott
posted on 23/8/10 at 09:08 PM |
It's a bearing which always touches the centre of the pressure plate, and when spinning is noisy as it's worn out.
Depressing the clutch loads the bearing and takes up any play in it which means the noise goes away untill it is let out again.
It's always spinning.
The clutch doesn't require removal to change it, just the box needs to come off.
HTH
Stott
EDIT: it can either be a dedicated release bearing which would then be attactched to a release arm or it could have a concentric slave, which is a
combined slave cylinder and bearing in one which would require replacing to solve the noise issue.
[Edited on 23/8/10 by Stott]
sonic
posted on 23/8/10 at 09:13 PM |
Thanks very much for that,as i thought but you know when you start to dought yourself!
Thanks again
snapper
posted on 24/8/10 at 05:07 AM |
Unless the plate and cover has been changer recently it is always considered worthwhile to change the whole lot while the the engine and box are
appart
I eat to survive
I drink to forget
davrus
posted on 24/8/10 at 06:48 AM |
Hi ya.
Just a little bit of my opinion
I would say it is a bearing in the gear box itself and not the release bearing..
When the clutch pedel is released the release bearing should return enough to release most preasures off the release bearing so you should not get any
noise from it.
If it was the release bearing you would hear it at its worst when the pedel is applied.
When you applie the cluch and the car is statioary the only bearing then spinning is the release bearing, none in the gear box, release the clutch
then the gear box bearing start to turn again and thrust race will relax.
So new gear box sir.
turboben
posted on 24/8/10 at 07:42 AM |
^^^+1
sonic
posted on 24/8/10 at 10:01 AM |
Now i am confused!!
Anybody want to give any advice
Stott
posted on 24/8/10 at 11:34 AM |
It can be either input shaft bearings or the release bearing as said above. The release bearing gives this sort of fault too.
Try to load the clutch pedal slightly, like 1" or so but not totally depress it, if the noise goes it'll likely be the release bearing, if
you have to depress the clutch fully to stop the whine, then it'll more likely be the input shaft bearings.
If there is a slight delay between depressing the clutch and the whine stopping, then defo the input shaft bearings.
hth
Stott
sonic
posted on 24/8/10 at 08:14 PM |
assuming it the input shaft bearing is it possible to change in your garage at home or is it a specialist job,it maybe worth him changing both the
bearings at the same time if possible
Stott
posted on 25/8/10 at 10:36 AM |
It's possible but if he doesn't have the pullers required, or a manual for the box, and is at all uncomfortable about splitting it then he
could end up in a pile of cogs and brass quite easily, if it's an E36 then the boxes can be had from about £30 up so it's no contest
really.
I sometimes navigate in night events for my mate who has an E30 with an E36 box and this is how much he gives for them if they knacker up.
It's not worth the potch really.
Stott
