davrus1975
posted on 30/8/10 at 08:16 PM |
Coolant expantion tank
Hi ya
Not sure what my rad was originally out of but i have one inlet and one out let as you would expect. Now i also have a little bore pipe coming out
just above the filler neck with a presurised cap.
I will obviously attach a hose to the small pipe then lower it in to the bottom of a bottle.
I asume the water will then be released into the bootle and then drawn back in to the radiator.
Now the question is
Does it matter wether i mount the bottle lower than the radiator cap or not? as from what i understand it works off a vacum rather than gravity.
Cheers in advanse
Davrus
coyoteboy
posted on 30/8/10 at 08:38 PM |
So long as the end of the hose is submerged at all times you can put the bottle where you like, as you say it's pressure-fed, not gravity fed.
davrus
posted on 30/8/10 at 08:52 PM |
That sounds good to me.
I will lower the pipe into the bottle so it is about 1cm from the bottom.
