Author: Subject: Has anyone made a bulkhead/scuttle?
marcjagman
posted on 15/9/10 at 08:35 PM Reply With Quote
Has anyone actually made a scuttle or has everyone bought a plastic one? I have tried to make one and it looked great until it came to tack weldig it in place, then it warped. Didn't do that in the book, or did it? is just a case of working till it's smooth and ripple free with a bit of filler here and there? Anyone got pictures of steel ones that they have made?
OOOOPS!!!!!!! POSTED THIS TWICE< WHAT A P(LL$CK I AM (must be my age)
[Edited on 15/9/10 by marcjagman]
austin man
posted on 15/9/10 at 08:47 PM Reply With Quote
you could rivet it
I made one welded it and skimmed with filler to get flat looked okay when finished. The bought ones are lighter and look asthetically more pleasing in my opinion
RichardK
I did, there is some cruel people that take the pi55 as my scuttle seems to be structural, I think its got something to do with having to have 2 people to lift it on and off .
Now like this but still the same scuttle
I did have to patch the triangles in as the sheet of steel I stole from somewhere was a bit too short!
Hope it gives you an idea
Rich
[Edited on 15/9/10 by RichardK]
Gallery updated 11/01/2011
marcjagman
posted on 15/9/10 at 08:51 PM Reply With Quote
Thought it was just me that was doing something wrong. feel better now I know that others have gone through the same thing.
RichardK
posted on 15/9/10 at 08:54 PM Reply With Quote
Nah, you're not alone, its a proper bugger to get it to look right
paulf
posted on 15/9/10 at 09:13 PM Reply With Quote
I made mine as per the book , I used 12mm x 3mm strip for edging and tack welded the 18 gauge covering and then finished with filler as required.
Paul
steve m
posted on 15/9/10 at 10:10 PM Reply With Quote
I made mine as per the book and wrapped it in Alui
One of the most pleasing aspects of my car, and once all the dimensions, curvetures etc worked out, was very easy to make
(i have never done anything like this before !!)
RK
posted on 16/9/10 at 12:20 AM Reply With Quote
or the easy way out: AGM Sportscars 85 pounds, one glass fibre scuttle... ntdwm
[Edited on 16/9/10 by RK]
mark chandler
posted on 16/9/10 at 06:09 AM Reply With Quote
I made mine out of ali, made an MDF buck, ie front and rear plates then rolled the ali around the outside and folded the edges in.
Once the curves were done with the folded edges it had strength, next step to weld the sides, took 1/2 day to make and cost £20.
kj
posted on 16/9/10 at 06:42 AM Reply With Quote
Made my frame as per the book covered with ali.
