Author: Subject: Speedo cable modification
davrus
posted on 15/10/10 at 06:41 AM Reply With Quote
My cable is about 2 feet too long, Is it possible to cut the outer casing down then trim the inner cable?
Is the inner cable square all the way down it or only on the ends.
Many thanks
posted on 15/10/10 at 07:18 AM Reply With Quote
ends only.
can you not route it in a way to take up the slack?
failing that, check out speedy cables - will make you one to your spec.
blakep82
posted on 15/10/10 at 07:23 AM Reply With Quote
2ft, over to the passenger side under the dash and back again?
________________________
splitrivet
posted on 15/10/10 at 11:25 AM Reply With Quote
Cut mine down used a wire straight crimp to join the inner, then sleeved the outer cut ends with thin wall steel tube and crimped this over the outer, works OK.
Bob
paulf
posted on 15/10/10 at 01:33 PM Reply With Quote
I cut down a sierra one and rejoined the outer just by pushing each half into a bit of rubber hose about 6 inches long and then secured with jubilee clips.It has been ok for the last 6 years.
Paul
paulf
posted on 15/10/10 at 01:35 PM Reply With Quote
Paul
paulf
posted on 15/10/10 at 01:37 PM Reply With Quote
Just remembered i used an escort cable for the inner as it was shorter than the Sierra one so just cut the outer to suit, the escort cable had a screw fitting for the gearbox so couldn't use that.
Paul
Paul
davrus
posted on 15/10/10 at 06:53 PM Reply With Quote
Thanks for replys.
I think i will run it around under the dash and leave it the lenth it is.
Thanks again
