Author: Subject: Angled Fog Light Surround
Bumble
posted on 23/10/10 at 08:35 AM Reply With Quote
Anyone know where I can get an angled light surround for the 95mm sized rear lights. It's for the Fog Light and Reverse light required so that they are level when fitted to the back panel.
There's some on E-bay but they are mahoosive!!
Was planning on looking at Exeter Show but plans to travel there have been scuppered at the last minute!!
Thanks,
Matt
stevegough
posted on 23/10/10 at 09:03 AM Reply With Quote
I found myself in the same position - £12 each as I remember? so I bought some black ducting (B+Q) which was designed to fit through a cavity wall of any thickness - hence it was one tube which was a tight fit inside another. I then cut it diagonally, cut a a slot along it ( as it was a couple of mms too big) and, after shaping it to the arch, superglued it to the lights.
Wasn't easy as the arches curvature isn't uniform - but I got there in the end.
[Edited on 23/10/10 by stevegough]
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
