Author: Subject: How to fit a prop shaft?!
B120WNY
posted on 2/11/10 at 09:33 PM Reply With Quote
Evening Guys,
Ive been trying to fit a sierra prop onto my Mac#1, and it wont fit unless the prop is split. Its looking like I need to remove the flanged face that goes onto the diff. Its 110mm dia, and the opening down the tunnel is only 90mm.
However prop doesnt seem to have "normal" circlips, anyone have any ideas on how to split the prop and fit the damn thing!?!?
Many thanks in advance.. )
RichardK
posted on 2/11/10 at 09:39 PM Reply With Quote
What about unbolting the dif on a trolley jack and just move it back and down a bit, would that give you enough room to jiggle the prop in form above?
Rich
Gallery updated 11/01/2011
Danozeman
posted on 2/11/10 at 09:46 PM Reply With Quote
AS Rich says above, could you not remove the diff and slide it in from the rear??
You dont want to split the u/j's as youl never get them back together in situ. You shouldnt have to either.
Dan
B120WNY
posted on 2/11/10 at 09:55 PM Reply With Quote
Ive tried both, to slide in from the front is a no go because the dia. of the rear plate that bolts onto the diff.
From the rear is the same, the mount is wider than the chassis forming the tunnel, doesnt seem to fit in any way other than splitting!
Il give the guys a call in the morning
Ben_Copeland
posted on 3/11/10 at 12:35 PM Reply With Quote
Definately something not right if it's that tight. Is it too long ?
Ben
Locost Map on Google Maps
Enter Your Details Here
