Author: Subject: Exhaust exit trim
Lightning
posted on 12/11/10 at 02:58 PM Reply With Quote
Exhaust exit trim
I have two exhausts exiting through the rear panel. i could do with 2 rings of ali or stainless to bolt to the body to prevent discolouration of the paint.
Where could I get some. My cutter wouldnt make a neat enough job. I suppose I could use small drilled holes and a file
about 75mm id and 115od
Any thoughts??
carpmart
posted on 12/11/10 at 03:13 PM Reply With Quote
andy7we can cut some rings for you on his water cutter!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
RazMan
posted on 12/11/10 at 03:21 PM Reply With Quote
I used an alloy tax disc holder to 'sandwich' a hole which I cut in stainless mesh to let my exhaust through. It is obviously heatproof and even has the ickle bolts supplied - it looked as if it was designed for the job
[Edited on 12-11-10 by RazMan]
Raz
Lightning
posted on 12/11/10 at 04:27 PM Reply With Quote
Razman, funny you should suggest that as that is what I have done. The problem is they are just too small as when the back section hinges, they catch.
