Thinking about it
posted on 23/11/10 at 08:23 AM |
Making a GRP mould
Most information states to use 2 pack paint to paint the buck, polish it then make the mould from it.
Not having any 2 pack paint and also it not being too friendly. Is it possible to coat the buck in flowcoat, then sand and polish then take the mould
from it?
stevebubs
posted on 23/11/10 at 09:06 AM |
I just painted it with normal paints from halfords....
tegwin
posted on 23/11/10 at 09:46 AM |
You just need a non porous surface that will take polishing..... I have used white emulsion paint designed for outdoor use in the past....
clairetoo
posted on 23/11/10 at 10:14 AM |
I use a polyester based spray filler which don't react with the gloat , and leaves a smooth satin finish.
If you want it shiny , the mold can then easily be polished with a bit of Tcut...
Its cuz I is blond , innit
Claire xx
Will weld for food......
alexg1965
posted on 23/11/10 at 11:41 AM |
Found this website whilst looking for some supplies which has some great "How to" videos.
Link
Triton
posted on 23/11/10 at 02:36 PM |
I have used allsorts in the past with no dramas until earlier this year I painted my kayak plug with celly then 3 or 4 coats of clear laquer. Left it
to cure then polished it...waxed the whole thing 6 times and even used pva release as I have done in the past...But the gel coat lifted the paint in
places which I would have seen if only I hadn't pigmented it.
Once mould was made and ready for popping it I had a cow of a job to get the plug out only to find the reaction that had taken place, first of all it
looked like the mould was buggered but it left laquer in a weird pattern all over both halves of the mould.
I had to resort to 3 solid days of nowt but washing with thinners to get it all off......so don't use celly as summat has changed with that
stuff and I'm not the only muppet to find out.
Use durabuild, it's expensive but wow what results as it can be highly polished and unlike paint won't lift.
www.tritonraceseats.com
www.hairyhedgehog.com
Fred W B
posted on 23/11/10 at 05:24 PM |
Another vote for Durabuild, I'm a complete amateur at this (or was at one stage) and it works for me. I added some blue pigment to it.
Fred W B
pattern feb 10 - 06
[Edited on 23/11/10 by Fred W B]
