Author: Subject: Sticking Rubber Trim To GRP?
Northy
posted on 21/6/04 at 10:42 AM Reply With Quote
Hi all,
What have others used to stick rubber trim to GRP? I'm using some of the thin rubber type U trim, without the metal insert so it won't clip on on its own.
Graham
Mk-Ninja
posted on 21/6/04 at 11:23 AM Reply With Quote
Sikaflex works well, but use masking tape to stop you getting it on areas you dont want it. Its a bugger to get it off where you didnt want it.
I'm sure I've got one, just don't know where I've put it
posted on 21/6/04 at 11:55 AM Reply With Quote
We used rubber solution glue as in a puncture repair outfit to stick it to aluminium. Let it tack off before you apply the two surfaces together
locoboy
If its only for SVA (temporary) then maybe silicone will do it? It can be picked off afterwords with you fingers
Locoboy
tractorboy
posted on 21/6/04 at 01:23 PM Reply With Quote
evo stick works to hold stuff on long enough for sva and can be picked off afterwards.
paulf
posted on 21/6/04 at 09:45 PM Reply With Quote
I used UHU adhesive it is clear and slightly flexible.
Paul.
Northy
posted on 22/6/04 at 05:08 PM Reply With Quote
Well I tried some Evostick today, did the trick nicely. Has the added bonus of peeling off again if you get it somewhere you didn't want it
Cheers all,
Graham
