Author: Subject: brackets
aaron-wxm
posted on 10/1/11 at 03:25 PM Reply With Quote
brackets
hi all ive baught myself a caterham replica
need to start making brackets for cycle guards, headlights and all others
could some1 show me some pics of theres or links to guides please
thanks in advance
femster87
posted on 10/1/11 at 03:37 PM Reply With Quote
hi mate, do you know what uprights you've got? cortina's or sierra. if they are sierra's I know GBS stock them with insert mushrooms already welded on. and not too expensive i think
James
posted on 10/1/11 at 04:31 PM Reply With Quote
What actual car is it though?
You said before "based on plans he bought". So it's a Locost? Based on the Ron Champion book? Or a Roadster by Chris Gibbs? A Tiger Avon?
They're all very different beasts when it comes down to it.
James
aaron-wxm
posted on 10/1/11 at 08:44 PM Reply With Quote
right i start again...
... im new to kit cars and i will be asking alot of questions
what are uprights?
i think (find out tmoro for sure) its a caterham replica and i think he used the ron champion book does that sound about right?
thanks
aaron-wxm
posted on 10/1/11 at 09:27 PM Reply With Quote
also im going to make my own pannels
alli or steel better? & which size thickness?
thanks
James
posted on 15/1/11 at 01:32 PM Reply With Quote
If it's based on the orginal Ron Champion book then it's a Locost.
You'll have a much easier time of it when posting if you stick to calling it that!
The uprights are the big chunk of cast metal that the wishbones attach to. They hold the hub to which the wheel bolts!
If your car has been kept to standard Champion plans then your uprights will be from a Cortina.
However, a lot of people used the similar Sierra upright as it is/was cheaper.
Hope that helps!
James
James
posted on 15/1/11 at 01:33 PM Reply With Quote
thanks
Like in so many cases, it depends what you're doing with them.
But it's probably best to say use ali. I used 1.2mm stuff.
HTH,
James
brookie
posted on 15/1/11 at 05:45 PM Reply With Quote
could help if u put your location as well m8 people near u could come and help u out
