Author: Subject: fence and high wind interface
theconrodkid
posted on 7/2/11 at 09:34 AM Reply With Quote
my back fence got blown down,the posts are 4X4 concreted into the ground and 2 have snapped off at ground level.
is there any way to replace the posts without digging up huge lumps of concrete?
i hate hard work btw
who cares who wins
pass the pork pies
mcerd1
posted on 7/2/11 at 09:45 AM Reply With Quote
is the concrete big enough to drill in some anchor bolts around the posts ?
mookaloid
posted on 7/2/11 at 09:53 AM Reply With Quote
Have they got reinforcing bars inside? it may be possible to straighten them up and repair them using an epoxy cement mix and a former.
Edit: sorry I for some reason like me not reading the OP properly I thought they were concrete posts
[Edited on 7/2/11 by mookaloid]
norm007
posted on 7/2/11 at 10:03 AM Reply With Quote
I take it the posts are wood and concreted into the ground???
I had this with a gate post 3 x years ago.
I borrowed a big Hilti drill and bits, drilled out the remains of the post from the concrete, (creating a concrete socket),new posts were planed off a couple of mm`s, then bought from Wickes a small bag of concrete repair powder!!???? mixed this up into a slurry and poured it around the new post which had been slipped into the concrete socket.
My gate is still standing tall 3 x years on!!!
Not too much hard work, and only took about an hour once I had everything in place.
Hope this helps!!!!
Something about this, so very wrong.....I have to laugh out loud, I wish I didn`t like this!!!!!!!!!!!!!!
Humbug
posted on 7/2/11 at 10:34 AM Reply With Quote
I did something similar to Norm. If the concrete is still in reasonable condition, it can be reused as he mentioned
theconrodkid
posted on 7/2/11 at 11:18 AM Reply With Quote
cheers peeps,looks like a small hilti to dig the old wood out then
who cares who wins
pass the pork pies
norm007
posted on 7/2/11 at 11:27 AM Reply With Quote
Where abouts on a "small damp island" are you?
I can get hold of a Hilti if your near me?
Norm
blakep82
posted on 7/2/11 at 11:40 AM Reply With Quote
i thought fence and high wind into face look amusing
________________________
posted on 7/2/11 at 11:58 AM Reply With Quote
There's always these things...
Metpost
But heaving out the old wood and putting a new post in is probably a better way of doing it - but not so quick...
mookaloid
posted on 7/2/11 at 12:26 PM Reply With Quote
just a thought - the original posts probably broke at the bottom because they were rotten at that point.
They rot there because it's only those couple of inches where soil is in contact with the posts and hence they always break there.
When you put the new ones in, haunch some concrete found the posts at the base to keep soil from contacting the wood and they will last years longer.
omega 24 v6
posted on 7/2/11 at 12:46 PM Reply With Quote
Drill a few holes through the remainings posts. Fill with petrol/parrafin/similar set alight and leave. The pick out whats left and hammer in the new post.
posted on 7/2/11 at 01:02 PM Reply With Quote
Also stand the posts in a bucket of your favourite preservative (e.g. creosote) for a few hours until they're well and truly saturated with the stuff.
DarrenW
posted on 7/2/11 at 02:08 PM Reply With Quote
This is what i have always done, takes time to soak in but worth it. if i havent had suitable old bucket ive just kept brushing it on for several hours. Maybe thinned down old engine oil will preserve them - not eco friendly though.
I know someone who wrapped plastic around bottom of posts before concreting in - have a guess what happened?
Daddylonglegs
posted on 7/2/11 at 02:39 PM Reply With Quote
Drill out the best you can to get rid of the old post stump (probably pretty rotten anyhow so shouldn't be too hard). Then fit the Metaposts (in DJ's link). Use an offcut of 3"x3" post to ram the Metapost home then fit your 4" x 4" s, simples
mangogrooveworkshop
posted on 7/2/11 at 03:26 PM Reply With Quote
Char burn the surface of the wood that you want to protect where it comes into contact with the soil.......bet it wont rot in a thousand years.
They did up old fires in time team sites and the char is still there 10 hundred years on
designer
posted on 7/2/11 at 04:50 PM Reply With Quote
Isn't it covered by your house insurance?
If it is, let contractors worry about it.
posted on 7/2/11 at 05:08 PM Reply With Quote
They became removable fence posts?
theconrodkid
posted on 7/2/11 at 09:28 PM Reply With Quote
i,m west London.
ill have a go at drilling it out first,the other fence has metapost and is a bit better tho it does sway in the wind.
anyhow,as soon as summer comes i intend getting out of this hell hole and heading for a life as a beach bum on the south coast
who cares who wins
pass the pork pies
