PuppiesBalls
posted on 24/2/11 at 02:17 PM |
Genuine Bosch 12v Automotive water / coolant pump (CHARGE COOLER)
1200l/hr up to 0.3bar head pressure, magnetic drive, so cannot leak. - 19mm push on fittings - Two pin receptical power and earth (Bosch injector plug
type) or use two spade recepticals direct to terminals.
Perfect pump for a charge cooler!
Brand new cost me £100 quid, would take £85+ postage:thumbs:
PuppiesBalls
posted on 27/6/12 at 01:19 PM |
Bump!
posted on 27/6/12 at 06:26 PM |
Someone obviously didn't read the for sale guidelines!
PuppiesBalls
posted on 19/10/12 at 11:07 AM |
Still for sale, fitted but never used!
Westy1994
posted on 19/10/12 at 12:04 PM |
The image is not showing as it has been deleted or moved, so I can't tell if it is suitable to use as a main water pump , to replace a mech pump
that is.. Can you confirm please.
PuppiesBalls
posted on 19/10/12 at 12:21 PM |
http://store.chiefenterprises.com/s.nl/it.A/id.2967/.f
Westy1994
posted on 19/10/12 at 12:28 PM |
Ah ok thanks, no its not suitable is it. I already have a davis craig already but a mate needs one also so thought yours may have done the job.
Good luck with the sale.
