Author: Subject: scuttle and dash pics
Miks15
posted on 21/3/11 at 02:34 PM Reply With Quote
Hey Guys,
Just about finished off my scuttle and dash, so thought id post up a few pics. Its all made from hand (apart from the stainless inset for the clocks and switches).
Scuttle is a steel frame wrapped in ally sheet. Dash is ally with a 3mm ally support strip on the back for strength. Also has bolts glued into it which pass through brackets and nut on the back so no fixing will be visible from the front once the dash is wrapped in foam and viynl.
What do you all think?
JAG
posted on 21/3/11 at 04:13 PM Reply With Quote
Looks like a really nice job - I would like to replace my GRP scuttle with an Aluminium one.
What are you doing for the bulkhead into the engine bay?
Have you made that panel too?
Got any photos?
I'm primarily interested in how you formed the step for the bonnet to sit on
Justin
blakep82
posted on 21/3/11 at 04:20 PM Reply With Quote
nice one looks awesome
________________________
MikeR
I'm impressed - well done. 1 question - where does the steering column go?
Miks15
posted on 21/3/11 at 04:40 PM Reply With Quote
Justin-
I have made that panel, how ever it is just a flat panel. The lip for the bonnet is on the actual scuttle. I cut out a 3inch (around there anyway) strip which was then riveted to the inside of the steel frame.(you can just about see it on the last upside down photo). When i comes to fit the bonnet ill just pack it out with foam to get the correct fit. This way it is the exact same curve as the scuttle itself.
Mike-
Im gunna steer with buttons Nah im just about to cut out the hole now, thought id get some shots first. Hopefully the next update pics itll be on the car with wheel and side panels. Wont be til april though thanks to uni.
stevegough
posted on 21/3/11 at 06:31 PM Reply With Quote
Nice job even got a rolled bottom edge for IVY !
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
