Author: Subject: How to mask up around a corner
bi22le
posted on 5/4/11 at 04:59 PM Reply With Quote
Hi all,
I hope you all have a buzz about the summer and the great days of driving ahead. I cant wait!!!
So, Im starting to mask up my rear tub to spray the arches. The problem being is marking tape dont like going side ways and creates creases which will give a 50p effect edge. Any nifty ideas around this. Insulating tape instead? Some other method of masking around corners?
Thanks in advance,
Biz
Please read my ring story:
tomgregory2000
posted on 5/4/11 at 05:05 PM Reply With Quote
What you want is 3m fine line tape, that stuff is magic
designer
posted on 5/4/11 at 05:35 PM Reply With Quote
Yep, fine line tape and then the normal stuff.
Also don't leave it on too long as it's a PITA to get off.
bi22le
posted on 5/4/11 at 05:45 PM Reply With Quote
Ah more money, I should of guessed!!!
Richard Quinn
posted on 5/4/11 at 06:11 PM Reply With Quote
Or you could get away with spending less and convince everyone octagonal arches are the future!
Confused but excited.
posted on 5/4/11 at 07:11 PM Reply With Quote
Fortunately 3M do a cleaning fluid in a pump can that removes adhesive in no time, if you do leave it on for more than a few days.
Works really well and smells of oranges.
Funnily enough it's called '3M Citrus Based Cleaner'.
austin man
posted on 5/4/11 at 08:44 PM Reply With Quote
cant you release the arches slightly or are they rivetted, if you can then do it and slide paper behind them
