Author: Subject: Procedure for painting GRP ??
tompat3463
posted on 10/4/11 at 07:43 PM Reply With Quote
Does anyone who the procedure for painting GRP panels ??
fancy a change of colour scheme and was wondering if I could do it myself ??
40inches
posted on 10/4/11 at 08:20 PM Reply With Quote
I changed all my blue panels to Black:
Cleaned all panels with thinners twice.
Rub down with 400 grit and soapy water, wash with clean water and dry,Tac Cloth.
Two coats Upol etch primer, don't flat back.
Four coats Gloss Black, leave 24 hours.
Flat with 1500 grit and then Tac Cloth.
Two coats Clear coat, leave for two weeks before buffing.
This is how I did it, may not be technically correct, but I am more than happy with finish.
Edit to say that this was with rattle cans, should be cheaper with a gun.
[Edited on 10-4-11 by 40inches]
austin man
posted on 10/4/11 at 08:22 PM Reply With Quote
preperation is the key to anything, Ive heard some people use etch primer and swear by it, personally I give the panel a good key with p400 and a good few coats of primer wet flat clean and dry and apply top coats never had a problem
tompat3463
posted on 10/4/11 at 08:34 PM Reply With Quote
ok thanks..
What do U mean by flatting back ??
Steve Hignett
posted on 10/4/11 at 08:59 PM Reply With Quote
It's just a technical term for rubbing down.
ie, rubbing back, making flat etc...
brookie
posted on 11/4/11 at 05:32 PM Reply With Quote
same here m8 went the same way look top as well my went from black to lime green
