femster87
posted on 16/5/11 at 07:16 PM |
windscreen fitting
I received this contraption today. Dont really know how to put it together, Any pointer would be appreciated. Thanks alot.
[Edited on 16/5/11 by femster87]
stevegough
posted on 16/5/11 at 07:54 PM |
Windscreen - I've got a pic like that!
GBS 'lightweight' windscreen
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
stevegough
posted on 16/5/11 at 07:57 PM |
You get the flat piece of rubber, and fold it into the channel. Then you push the glass into it.
Like this....
Luego Locost C20XE.
stevegough
posted on 16/5/11 at 08:03 PM |
Then you do the same with the bottom, and you will need to cut the ends to mitre the corners, finish by CAREFULLY drilling diagonally at the corners
so you can fit a screw at each side. I will say it is definitely not easy. Use 'Mr Muscle' cleaner to help ease the glass into the
rubber seating.
Luego Locost C20XE.
femster87
posted on 16/5/11 at 08:11 PM |
thank you very much, really appreciated would have a go tomorrow. thanks
big-vee-twin
posted on 16/5/11 at 08:12 PM |
Have a read at this linky
http://www.triangleltd.com
