Macbeast
posted on 4/6/11 at 09:07 AM |
Windscreen Fixing
On a sevenesque, the windscreen seems to be fixed to the scuttle by Y-shaped brackets held by two or three bolts either side. I assume I would use
penny washers on the inside, but would it be advisable also to reinforce the fibreglass scuttle sides ?
whitestu
posted on 4/6/11 at 09:12 AM |
Mine just has large washers and seems fine.
Stu
Daddylonglegs
posted on 4/6/11 at 11:26 AM |
Yet to do mine, but I would think that as long as the screen is resting on the scuttle and penny washers are used on the supports it should be fine. I
wouldn't think there is much side-to-side movement pulling on the bolts as the supports are normally pretty substantial.
HTH
Macbeast
posted on 5/6/11 at 04:00 PM |
Thank you gentlemen
