jossey
| posted on 20/6/11 at 03:51 PM |
New dashboard Selfbuild. Comments???
So ive decided to have a go at building a dash for my locost.
I Started with some cardboard then wood and then building a mold using fibreglass and the sanding filling sanding filling sanding filling sanding
filling sanding filling sanding filling sanding filling sanding filling sanding filling sanding filling sanding filling sanding filling.....
and then made another mold of the finished article.
Then Got my friend at Predator Auto shop to spray it for me to see how it looked. Anyway see below.
  moldfirstgo
  Moldgo1
  New dash Hand made
  Newdashlogo
What do you think.????????????
It slides into the existing scuttle perfectly.
I balanced it into the car to see how it may look......
  Fitted dash sort of
cheers
Dave J
[Edited on 20/6/11 by jossey]
David Johnson
LBMEFM
| posted on 20/6/11 at 06:23 PM |
Could do with a bit more sanding filling sanding filling sanding filling sanding filling sanding filling sanding filling   , no seriously it looks
very good. Barry
jossey
| posted on 20/6/11 at 08:27 PM |
Glad to see someone likes it :-)
David Johnson
loggyboy
| posted on 20/6/11 at 09:13 PM |
Finish looks top notch! Not quite so sure about the snake motif - but each to his own as they say!
jossey
| posted on 21/6/11 at 06:41 AM |
Lol I was unsure to but it lOoks good when on the car :-)
David Johnson
kendo
| posted on 21/6/11 at 08:13 AM |
Hi
Obviously a lot of effort gone into it.
One question though. Is the radius along the bottom edge 19mm or greater?
I am of course assuming that your car hasn't gone through IVA (or SVA if its older).
Just a thought because it will cause you issues later and all that hard work could potentially be wasted.
jossey
| posted on 22/6/11 at 08:46 AM |
cr*p pants. not it isnt but i can mod it quite easy i thinks.
i did see something about the radius a while back. the plan was to add some think edging to it after using it for track days for a while.
thanks for the note though.
i guess it will come off for IVA and ill get a piece of Perspex and use that till it passes.
then it will fall off :O)
DJ
David Johnson
