Ben_Copeland
posted on 23/6/11 at 08:36 PM |
Help Concealing Gap
I've got a bit of a gap
The side panel is hard up against the chassis, but the nose is slightly too narrow.
Anyone have any good ideas how to hide this neatly? without being obvious....
Dont want to cut the side panel back behind the wishbones, as it took me ages to cut the wishbone holes!
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
posted on 23/6/11 at 08:45 PM |
Sikaflex Take the nose off and fill the hole then rub the edge of the panel down to taper it in.
fesycresy
Put some Caterham style carbon canards in front of it.
Would you see it then, that should take your eye off it?
Ben_Copeland
posted on 23/6/11 at 08:52 PM |
I was thinking about them, and I think I'll get some anyway. But I'm thinking they are usually further forward and you'll see
behind.
Ben
Roadster
Ben_Copeland
posted on 23/6/11 at 08:54 PM |
Also a good idea, does sikaflex go that hard? Or you just talking about rubbing the fibreglass down?
Ben
Roadster
posted on 23/6/11 at 11:11 PM |
Sikaflex was a tongue in cheek suggestion, it gets used for everything. Body filler would be my choice to blend it in.
indykid
posted on 23/6/11 at 11:40 PM |
Black sharpie it first and see what it looks like once it's not a white fibreglass edge
What's behind that edge?
Ben_Copeland
posted on 24/6/11 at 03:48 AM |
Behind? Chassis and wishbone brackets. It's sitting tight to chassis.
I'll try black marker first, maybe a small edge trim.
Ben
Roadster
