Author: Subject: 106 Sunroof Drains?
posted on 27/6/11 at 07:57 PM Reply With Quote
106 Sunroof Drains?
Anyone know where they are in the sills?
Driverside sill fills up then floods the rear footwell. I've had it leaning towards the nearside and that stops it.
Any idea where in the sill the water drains out?
lotusmadandy
posted on 27/6/11 at 07:59 PM Reply With Quote
Drill a 3mm hole in the bottom of the sill????
One at each end should do it.
lotusmadandy
posted on 27/6/11 at 08:15 PM Reply With Quote
OOPS....
I didnt read the thread properly
On my 206 the drain is on the end of the sill,under the wheel
arch front and back.They get full of crap and block up.
I bet they are the same on the 106.
Guinness
posted on 27/6/11 at 08:35 PM Reply With Quote
Just checked the rear wheel arches / sills. Nothing there.
http://www.106owners.co.uk/forums/archive/index.php/t-7469.html suggests they drain into the sills and then out of holes?
Will have to wait until the weekend before having a look at the front end.
austin man
posted on 27/6/11 at 08:39 PM Reply With Quote
blast some compressed air from the top that should clear the drains usually drains to front and rear
mangogrooveworkshop
posted on 27/6/11 at 09:15 PM Reply With Quote
Duct tape the thing shut .......keeps the water out...
Or give it to me so I can drive it to italy...... then down to Naples so the mafia can use it
lotusmadandy
posted on 28/6/11 at 07:14 AM Reply With Quote
Ok
firstly,i will appologise for passing on duff info.a friend
owns a garage and assured me the drains were as said.
I have just delivered to stokesley and i examined a 106 that
was in the garage.the drains are most definately on the
bottom of the sill.one at the front and one at the rear.
