Author: Subject: IVA Wing Mirrors
davidimurray
posted on 28/6/11 at 10:02 PM Reply With Quote
IVA Wing Mirrors
Can anyone reccomend me any wing mirrors that would be suitable for IVA ?
I've seen these http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ViewItem&item=300571100196&ssPageName=ADME:B:WNAFP:GB:1123 on ebay - has anyone used them succesfully?
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
loggyboy
posted on 28/6/11 at 10:10 PM Reply With Quote
Clearly states they are IVA ok, so whats the query?
davidimurray
posted on 28/6/11 at 10:14 PM Reply With Quote
I was wondering if anyone had used them and how they had found and also if there were any better reccomendations out there. Although the advert says IVA approved you wouldn't have any comeback if they didn't pass - I've had parts from some of the 'big' parts supplier sold as IVA ok and on checking them I have found that they are not - once bitten twice shy!
Stott
posted on 29/6/11 at 05:39 AM Reply With Quote
I understand you may be talking about the glass size, however at 6"x4" it's bound to be ok, but I thought I'd mention again for all those reading that exterior mirrors are exempt from the exterior projections test at IVA.
Section 16: Exterior Projections, Page 120/282 "The assessment will not apply to exterior mirrors"
Plenty of examiners pick people up on this but it's another case where they should read the book thoroughly first.
Stott
russbost
posted on 29/6/11 at 07:12 AM Reply With Quote
Hi
They look almost identical to the ones I use on the Furore F1 for IVA, have successfully passed twice recently with these, they may not be identical as my mirror heads measure more like 3 .25 x 5", but the tester raves about them, & believe me the Furore does not lend itself well to the rear view test, effectively being single seater positioning.
I can do a set to a fellow locoster for £13.95 + £3.95 P & P if that helps. I have them from stock.
Rgds Russ
40inches
posted on 29/6/11 at 08:09 AM Reply With Quote
Stott
Can you be more specific on the exact location in Section 16?
I have IVA version:6.01 09/05/2011 running from pages 131 to141 and can't find the "The assessment will not apply to exterior mirrors" part.
deezee
posted on 29/6/11 at 08:15 AM Reply With Quote
Its Section 16, Exterior Projections, on the 2nd page, under method of inspection. Top of that page.
40inches
posted on 29/6/11 at 08:25 AM Reply With Quote
Ah! Got it. Thanks for that
davidimurray
posted on 29/6/11 at 12:35 PM Reply With Quote
Russ
Do you have any pics of the mirrors you could post? I can't seem to find them on your webshop and your ebay link doesn't seem to work.
Dave
daviep
posted on 29/6/11 at 02:22 PM Reply With Quote
Stott
That is true however, section 8 Indirect vision states 7. All mirrors must have an acceptable approval marking or have equivalent characteristics to a mirror approved for use on a vehicle of the same category as follows:
•The reflective surface must be encased in a protective housing
•surfaces contactable by a 165mm sphere (interior) or a 100mm sphere (exterior) must have a radius of curvature of at least 2.5mm – except fixing holes or recesses less than 12mm wide, which must be blunted.
I always thought they were exempt how ever I was browsing the manual last night and noticed this.
Davie
russbost
posted on 29/6/11 at 07:57 PM Reply With Quote
Image attached, sorry haven't had a chance to get them on the website or ebay as yet & thanks for pointing out that the ebay link is way out of date! I will update it.
[img] IVA ok mirrors
IVA ok mirrors
[/img]
I should point out the picture is taken of the mirrors as they come out of the box, the mirror head should be rotated 180 degrees to the head for the correct orientation, they'd look a bit strange when fitted otherwise!
davidimurray
posted on 29/6/11 at 08:29 PM Reply With Quote
Thanks Russ - you have a PM
Dickyboy
posted on 30/6/11 at 03:30 PM Reply With Quote
I passed the IVA with these, or ones remarkably similar, only bitch was one had M8 LH thread, with no nuts(?) provided. They are good and don't vibrate too badly.
russbost
posted on 2/7/11 at 06:21 PM Reply With Quote
I can assure you mine both have 10mm thread!
stevegough
posted on 2/7/11 at 07:08 PM Reply With Quote
Stott
I don't know why you are worrying about it, 40inches? By the time you are ready for IVA, everybody will be getting around in "Star Wars" type speedsters
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
40inches
posted on 2/7/11 at 09:41 PM Reply With Quote
Stott
I'll have you know that it is nearly ready for IVA, sort of, almost, very close, possibly.
stevegough
posted on 3/7/11 at 06:33 AM Reply With Quote
Luego Locost C20XE.
